“c” alternator bracket vs Aluminum head problem?
Old Dec 16, 2020 | 09:51 AM
CuttyShark's Avatar
anyone with Aluminum heads ever run into this problem with the C and H alternator brackets? The crank, power steering and Vintage Air all lineup perfectly but the alternator is one groove back from perfect. The alternator is from Autozone and is new and was correct part number for that year according to their system. The belt does go on but squeels back and eventually gets chewed.
did the stock C and H bracket need a spacer behind between the bracket and heads OR did the 1970 Olds 442 with 455 have a Dual groove pulley originally? That seems to be only immediate solution so I went ahead and ordered one.
Old Dec 16, 2020 | 10:49 AM
A single groove pulley is correct, and while it is dimensionally the same, that is not the correct alternator for a 1970 442. There should not be any spacers required.
Old Dec 16, 2020 | 10:57 AM
Old Dec 16, 2020 | 11:02 AM
I have aluminum heads, Vintage Air, and everything lined up on my car. I don’t recall what pulleys I used, but they are the correct codes for a 69 with factory air.
Im using a CS-130 series alternator. The original application had a serpentine belt pulley. I transferred all the v belt hardware and pulleys from the old alternator to the CS part, everything lined up.
Wish I could be more helpful. Was this a factory air car you converted to Vintage Air? If so, did everything line up before? If this is a new conversion, I’d suspect wrong water pump (with the matching but incorrect pulleys).
Old Dec 16, 2020 | 11:05 AM
I’m using the same alternator brackets you are. I think the ones Joe posted are technically the correct parts for the 68-69 cars, but dimensionally I think the function the same.
ill be taking apart my car soon for a water pump replacement. If you haven’t found a answer to your problem I’ll report back with the pulley codes I’m using.
Old Dec 16, 2020 | 11:59 AM
P/N 398667 front bracket and 398887 rear brace are the same for all 68-71 A/C cars, according to the parts book.
Old Dec 16, 2020 | 12:10 PM
Factory pulleys for 1970 are:
KF 399404 Water Pump (three groove)
KC 399405 Crankshaft (three groove)
KH 399406 PS Pump (two groove)
1949355 Alternator (single groove)
Old Dec 16, 2020 | 12:22 PM
classicmuscle442's Avatar
Is hub on water pump set deep enough, power steering belt looks like it could go back too
Old Dec 16, 2020 | 01:34 PM
CuttyShark's Avatar
I think i may have found problem. The bottom back H bolt hole is under the head ARP bolt. The original head bolt had a stud. Here are OEM bolts. The rear bolt would give the alternator bracket a little more height and push the bracket forward. Which Of these bolts is right one to replace the ARP bolt?
Old Dec 16, 2020 | 02:00 PM
Loaded68W34's Avatar
The longest one (second from the top) wound be correct.
Old Dec 16, 2020 | 02:12 PM
CuttyShark's Avatar
OR. Maybe the bracket is bent!?!!??
i bought the bracket off here five years ago when I started the project. Look how it curves back toward driver
Old Dec 16, 2020 | 02:19 PM
The long one is also the only bolt in that photo that's 7/16". The other three are 1/2" and won't work anyway.
Old Dec 16, 2020 | 02:38 PM
CuttyShark's Avatar
Anyone have a Straight C bracket they can rush me?
Old Dec 16, 2020 | 03:06 PM
oldsmoboogie's Avatar
what’s your location?
Old Dec 16, 2020 | 03:32 PM
CuttyShark's Avatar
I am in Ontario California
Old Dec 16, 2020 | 04:59 PM
CuttyShark's Avatar
UHG
i had the later 71-76 style alternator bracket as a spare. Tried that and same thing. Off by about a groove.
Old Dec 16, 2020 | 06:13 PM
At first glance, it looked like the OP was using the later model alternator brackets, like what was on the mid 70s cars. After you posted the part numbers I looked closer and could see that they were the correct A body parts. That was my mistake.
Old Dec 17, 2020 | 11:42 AM
CuttyShark's Avatar
Well. I guess since BOTH the C/H and later 70s brackets both put the alternator in same place I have something else going on. The Power Steering pulley has correct spacers on back and lines up perfect M with WP and Crank
i found a Dual groove pulley and installed it and now all the belts are
70cutty
Apr 13, 2021 08:59 AM
matt506
Jun 10, 2019 05:24 PM
gbledsoe3
Aug 18, 2017 06:49 PM
ReallyWildStuff
Jul 20, 2017 06:45 PM
Nasty455
Sep 14, 2012 07:16 PM
