Value of c and g heads
Old Jun 28, 2020 | 03:51 PM
akspeedy's Avatar
I had the opportunity to pick up a set of c heads and a pair of g heads, they are all there as far as valves and springs but I consider them core quality as in they will need rebuilt what is the value? Thanks in advance for the help
Old Jun 28, 2020 | 04:43 PM
It’s really hard to rebuild cast iron heads economically compared to aftermarket aluminum. Add in the 50 hp bolt on, even more so. By the time you install guides, springs, valve job, porting, other machine work, etc it adds up to at least the cost of aftermarket
Old Jun 29, 2020 | 05:06 AM
Core heads typically sell in the $100-$250 a pair range. As noted, properly building a set of iron heads will rapidly reach the cost of new aluminum. Unless you care about looking correct or have rare W30 heads, think carefully about the cost.
Old Jun 29, 2020 | 11:48 AM
akspeedy's Avatar
Thanks Joe
That is about what I thought for cores, I had read and heard that the C heads flowed better than the aftermarket heads but I know technology changes so maybe they’re a lot better now, I had heads done last year they installed new larger valves and seats in my small block heads and filled the center port and I only paid $400 I know that’s small block but I didn’t think the price was bad and they turned out great, thanks for the reply I appreciate it, I’m sure the smart thing to do would just be to go with the aluminum aftermarket and have them port matched
Old Jun 29, 2020 | 02:16 PM
cutlassefi's Avatar
None of the stock iron heads flow better than any aftermarket head. At best they flow the same but all aftermarket heads have better combustion chambers and more efficient ex ports. Whoever told you different is clueless.
Hope this helps.
Old Jun 29, 2020 | 04:43 PM
akspeedy's Avatar
Thanks Mark I appreciate the knowledge that’s why I came here and asked, I’m still learning! Thanks again. I appreciate everyone’s help and knowledge
Hope this helps.
Old Jun 29, 2020 | 05:30 PM
11971four4two's Avatar
MOTORHEAD
Head Games
I purchased 2 sets of C heads and a pair of GA for $50 a pair
Now trying to get $40 for a pair of C heads
If they are rusted / damaged............ They are then good for SCRAP /parts
76sbo
Mar 5, 2020 10:33 AM
Bernhard
Sep 16, 2019 06:28 PM
Marx3
Jan 17, 2015 01:12 PM
arnoldjr
Sep 27, 2011 10:47 AM
