Block and crank
Block and crank
im getting ready to drop my block and crank off to the machine shop on Friday. I got it all tore down and everything looks good. Is there anything i should do to the block before it goes in to be hot tanked? There is some casting flash I’m going to grind down, should i do anything to the oil return holes?
Yes, you are on the right track. De-burr and port all oil drain back holes and any casting flash you see in the lifter galley area, port the oil return hole behind the camshaft timing gear.
Remove all of the oil galley plugs on the front and rear of the block, so you can see all the way through the oil galleys front to back, so that it will get cleaned out front to back.
The rear plug that feeds oil to the distributor gear must be removed and it is tough to get out, because it is a square plug and very tough to get the correct-sized square drive socket.
If you can't remove this one yourself, make sure and tell the shop that it must be removed before hot-tanking the block, and that they need to keep the plug and not throw it away.
You need to keep all the plugs that go into the oil galleys because they are all special straight-cut threads and not NPT threads.
Just want to add that if you cannot easily get the oil galley plugs out, especially the square drive one in back, please stop before you mess up the square drive hole in the plug.
85Cutty442
November 18th, 2016 03:10 PM
