Need pics of power steering bracket clearance to steering box on 66-67 Cutlass
Old July 8th, 2018, 05:08 AM
Battenrunner's Avatar
Please snap some pics of clearance and required mods to fit Big Block Olds into 66-67 Cutlass where the power steering pump gets close to the steering box.
I need to know how tight this area is before jumping into new brackets and pulleys....
I am interested in the bracket sets for 68+ up into these early cars, as well as aftermarket pulleys and serpentine conversions of any brand. I am seriously looking into the CVF kit as a possibility, because I need to mount accessories in front of the tall valve covers, because stock brackets and a/c and alternator won’t clear tall valve covers.
any help is appreciated
Battenrunner is offline
Old July 10th, 2018, 02:36 PM
tmaleck's Avatar
I don't recall this being very tight. I looked at my 330 with the 67 brackets and sits well above the box. My 403 with 71 brackets is worse. It puts the pump lower, under the alternator. I think the 67 400 mounts about the same as the 330, but others can chime in if I'm wrong.
Tim
Pump is up high above the steering box.
tmaleck is offline
Old July 10th, 2018, 03:23 PM
Thank you Tim, my issue is that I have the later model 1968+ Bog Block brackets that put the power steering pump down low on the driver’s side, right near the steering box...
Old July 10th, 2018, 05:32 PM
72 Olds CS
RetroRanger's Avatar
Search cvf on this site IIRC another member may highwaystar442 had some experience w them.
If it's helpful I can take a pic of mine BBO w low mount pump (72) in a 72.
RetroRanger is offline
Old July 10th, 2018, 06:40 PM
Thank you Retroranger. I am mainly looking for pics of 66-67 A body cars with Big blocks installed with low mount power steering setups, as the frames are narrower
Old July 11th, 2018, 04:30 AM
nicks1966's Avatar
You have to cut the lower bracket or it will hit the steering box, other than that all else bolts in with the correct spacers. the second picture is how I have the bracket cut. The frame is about an inch and a half narrower on the 66 & 67 models.
nicks1966 is online now
Old July 11th, 2018, 07:19 PM
Very good Sir!
is the second picture looking down or from under the car looking up?
Old July 12th, 2018, 04:40 AM
nicks1966's Avatar
The picture is from the side almost on top of the steering box. Do you want a picture from under the car?
Old July 12th, 2018, 05:45 AM
No, this is great, I just wanted to make sure I understood the frame of reference.
Thanks again!
67CSConvert455
July 3rd, 2018 08:15 PM
firefighter5174
December 13th, 2017 10:27 AM
billmerbach
April 16th, 2015 04:58 PM
80_cutlass
November 26th, 2009 07:11 AM
65az
July 4th, 2009 04:41 PM
Quick Reply: Need pics of power steering bracket clearance to steering box on 66-67 Cutlass
