Rocker arm question
Old June 27th, 2018, 07:23 AM
67Rocket's Avatar
Rocker arm question
After installing new lifters that are not "pumped up" do you guys leave the rocker arms loose or torque them down to start with? Thx
67Rocket is offline
Old June 27th, 2018, 07:54 AM
Actually, I try to "pump up" new lifters before installation by putting them in a coffee can full of oil and using an old pushrod in a drill press to compress the lifter cup, allowing oil to be pulled in.
If you are talking about stock, non-adjustable rockers, just torque them to spec. If you are talking about aftermarket adjustable, you need the lifters pumped up to set them properly.
joe_padavano is offline
Old June 28th, 2018, 09:02 AM
bw1339's Avatar
I like to turn the oil pump with a drill in all new engines I'm about to fire up. It lubes/primes the system and can give a warning if certain issues are going to occur.
bw1339 is offline
Old June 29th, 2018, 05:56 AM
edzolz's Avatar
Be sure your drill is on "reverse" because Olds oil pump turns counter clockwise.
edzolz is offline
Old June 30th, 2018, 09:09 PM
marty59's Avatar
Once the short block is together and the oil pump is primed, I'll get the oil flowing and drop in the lifters one at a time.
marty59 is offline
69CutlassAlex
March 24th, 2020 06:03 AM
Olds64
May 19th, 2019 02:44 PM
Supernaut72
50
February 6th, 2016 04:59 PM
DreWRoolZ
February 2nd, 2012 07:17 PM
kaptmikey
January 23rd, 2010 11:58 AM
Quick Reply: Rocker arm question
