B-heads 66 toro 425
Old May 1st, 2018, 09:44 AM
deadeyejedi's Avatar
B-heads 66 toro 425
Anyone tell me about cam bank angle ? Everything I read says b heads will work on a 455.my block has 39 degree cam bank angle and I believe these heads came from a 45 degree 425 block . I placed the head on my block put a rocker ,push rod ,and lifter in . And it appears the push rod is very close to the wall of the hole at the bottom of the head(1/16th of an inch maybe). Shouldn’t the push rod come out the bottom dead center of that hole?ive read that you can open up the size of the push rod hole in these heads for clearance at the machine shop. Is this acceptable or did I throw my money away?
deadeyejedi is offline
Old May 1st, 2018, 10:58 AM
You can open the holes if needed. This is not a big deal.
joe_padavano is offline
Old May 1st, 2018, 01:20 PM
Great that’s what I needed to hear thanks joe
L77F85
September 4th, 2016 03:42 PM
Paxtonshelby
December 29th, 2015 04:58 PM
lowkey235
August 12th, 2013 06:11 AM
vistacruiser1971
December 27th, 2012 07:35 AM
<Fuelie 425>
July 15th, 2004 04:29 AM
Quick Reply: B-heads 66 toro 425
