Distributor gear question
Old March 31st, 2018, 06:31 AM
big man's Avatar
Ok.I have a 455 with an erson cam. The distributor is a pertronix flamethrower with a steel gear. After some research and calling the cam company they said i needed to use the bronze gear. Ok, fine.
My question is how long until something messes up with the gears? Currently I only have maybe 100 miles on the engine. Its rebuilt and was only driven to work to work on it at the shop and was totally clueless about having to change the gears? It starts fine, runs fine and no problem getting the timing right thus far.
Also how do you adjust the distributor end play with the shims or check for clearances? Thanks
big man is offline
Old March 31st, 2018, 06:45 AM
Inline's Avatar
About gears, no idea, but you dont shim your distributor.
Cam pulls distributor shaft down when engine is rotating, to "rest" on the machined pad on the block, and that way sets the gear height correct.
Inline is offline
Old March 31st, 2018, 07:00 AM
big man's Avatar
I thought you had to put a shim at the base of the distributor to adjust for clearances to make sure the gear and cam are lined up right? Am I not correct..
big man is offline
Old March 31st, 2018, 07:29 AM
Gary
VC455's Avatar
Originally Posted by big man
I thought you had to put a shim at the base of the distributor...
Look at the bottom of the drive gear on your original distributor. Observe how shiny it is. That's because the distributor gear is cut so that it pulls down, as Inline said. Also see that there are no shims above your original gear and the top of the gear is not shiny.
Shims would only be needed if the gear had an opposite hand cut and pulled up.
On an Olds, a shim would take up space that is there to allow the distributor to seat fully.
VC455 is offline
Old March 31st, 2018, 01:34 PM
cutlassefi's Avatar
I’m guessing you have roller?
cutlassefi is offline
Old March 31st, 2018, 02:44 PM
big man's Avatar
Actually Marc you had this cam custom ground for me. Part # E540996.
Im just now getting this engine back together after a year or so later because you nor the cam card itself told me it was a 4-7 swap cam. Sucks because I had to pull my engine back out, have everything redone and $800 bucks later here I am...I made a thread on realolds about why my engine wasn't running right and couldn't figure out for the life of me why it wouldn't run correctly. After swapping intakes, carbs, and checking valve lash it just came down to just having the wrong firing order..who would've thought that?? Anyway, engines running good now and would like to keep it like that. Anyone have a bronze gear? I've spent plenty already lol
big man is offline
Old March 31st, 2018, 06:39 PM
cutlassefi's Avatar
Sorry I didn’t pass that along but there should’ve been a piece of paper in the box stating the same as well.
i have a new Comp #442 bronze gear for sale then if you want it, $50 it’s yours.
Old March 31st, 2018, 07:42 PM
Mr Nick's Avatar
Does your Pertronix distributor have the same shaft as an MSD unit? I've been running a stock melonized MSD gear with my Erson roller cam for years, all good.
Mr Nick is offline
Old April 1st, 2018, 08:40 AM
big man's Avatar
It says pertronix has a steel gear.
No ill effects just yet but before I drive this car again Im going to scrape up enough money and change out the gear.
big man is offline
Gary M
July 4th, 2017 05:54 PM
O-dawg
November 3rd, 2016 06:07 AM
Cman7713
Drivetrain/Differentials
March 20th, 2016 08:11 AM
drjr56
September 9th, 2012 08:05 PM
Jolly Green
July 19th, 2012 08:55 PM
Quick Reply: Distributor gear question
