Coolant Tube
Coolant Tube
Ref the metal coolant tube that comes out of the thermostat housing, I'm using a edelbrock 2151 intake. The metal tube is press fit into thermostat housing which is aluminum also, my question is how tight should the tube fit?
There is some play in it, should I use some silicone to seal it? I'm worried that it may leak.
Thanks!
Thanks!
Not necessarily Joe... Although, I did agree with you at first... Super Cars Unlimited has an aftermarket available...
The two dissimilar metals could be the reason the tube became loose, JMO....
http://www.supercarsunlimited.com/71...ing-d2801.aspx
gearheads78
Sep 10, 2010 02:26 AM
