Coolant Tube
Old Nov 2, 2016 | 03:49 PM
kev5696's Avatar
Coolant Tube
Ref the metal coolant tube that comes out of the thermostat housing, I'm using a edelbrock 2151 intake. The metal tube is press fit into thermostat housing which is aluminum also, my question is how tight should the tube fit?
There is some play in it, should I use some silicone to seal it? I'm worried that it may leak.
Thanks!
Old Nov 2, 2016 | 04:07 PM
If the tube is loose, it will probably leak.
Old Nov 2, 2016 | 05:17 PM
CRUZN 66's Avatar
Olds Fever
It will leak... Change the stat housing... I'm sure used ones are very plentiful at a reasonable price... New housing is less then $20 at NAPA...
Old Nov 2, 2016 | 05:19 PM
kev5696's Avatar
I figured that or use silicon which I really didn't want to do. Thanks!
Old Nov 2, 2016 | 07:05 PM
Silicone will not keep it from leaking.
Old Nov 3, 2016 | 05:46 AM
I think a magnet would disagree with that statement.
Old Nov 3, 2016 | 08:10 AM
CRUZN 66's Avatar
Olds Fever
Not necessarily Joe... Although, I did agree with you at first... Super Cars Unlimited has an aftermarket available...
The two dissimilar metals could be the reason the tube became loose, JMO....
http://www.supercarsunlimited.com/71...ing-d2801.aspx
Old Nov 3, 2016 | 08:36 AM
I was not aware that there was an aftermarket aluminum version. As you know, all the factory ones with the pressed-in tube are iron. The earlier aluminum ones use the rubber "J" tube.
dingusboy
Mar 8, 2014 07:09 AM
1k442
Feb 6, 2013 02:16 AM
oldspackrat
Dec 6, 2012 02:48 AM
gearheads78
Sep 10, 2010 02:26 AM
Diabolus
Jul 23, 2004 04:35 AM
