Where to order Braided Fuel Line
Old Apr 20, 2017 | 09:48 PM
AK71CutlassS's Avatar
Looking to order braided fuel line 10 inch or 12 inch long with AN-8 fittings. Not sure where to find this. I'd like to order off summit but can find where u can choose lengths and fittings
Old Apr 21, 2017 | 04:24 AM
Summit has what your looking for:
https://www.summitracing.com/search/...%20fuel%20line
https://www.summitracing.com/search/...ose%20fittings
Old Apr 21, 2017 | 05:06 AM
Don't forget to check Jegs for their price. It's sometimes a few cents cheaper. Both places will price match each other though. I've gotten good service from both places.
Old Apr 21, 2017 | 07:09 AM
csouth's Avatar
If you're not married to the braided lines, I'd check out the Earls hose and push lock fittings. They worked great for my setup.
Old Apr 21, 2017 | 08:40 AM
But will they crimp fittings on for my specific length and size fittings ??
Old Apr 21, 2017 | 08:42 AM
AlSo what's a good routing setup. Just an online between fuel pump and carb?
Old Apr 21, 2017 | 08:46 AM
They are not a crimp type fitting, they assemble and lock together inside the fitting collar.
Old Apr 21, 2017 | 08:57 AM
csouth's Avatar
You order the fitting and hose to make them yourself. Its a barb that is not coming apart. They are AN fittings on one side, hose barb on the other. When I messed on up, I had to cut it off. I actually had to heat the hose a little to soften it and use a little lube to press it on. I used Russell, not Earls. It's not braided, comes black or blue and its a neat easy assembly.
https://www.summitracing.com/oh/part...4393/overview/
https://www.summitracing.com/oh/sear...cation=oh&ar=1
Old Apr 21, 2017 | 11:29 AM
TripDeuces's Avatar
He was looking for pre-made stuff.
Old Apr 21, 2017 | 11:42 AM
csouth's Avatar
Judging by "Oldcutlass'" reply, if I misunderstood this as being "pre-made" I'm not alone. I have in my years never seen AN hoses and fittings pre-assembled unless it was application specific. Seeing as how he didn't specify anything other than braided fuel line, its hard know where its going. This is the reason we offered solutions that allowed him to make his own. If unless its a straight to straight connection, it is always better to assemble your own so the fitting is clocked correctly.
Old Apr 21, 2017 | 11:57 AM
Although thats not what I meant in my post, they do make premade hose assemblies and are available @ Summit.
https://www.summitracing.com/search/...%20fuel%20hose
Old Apr 21, 2017 | 12:10 PM
csouth's Avatar
I stand corrected, you meant otherwise...
I saw those before and he did say -8AN, those are -6AN. I still stand by my theory of making my own, but one size doesn't fit all...
70sx455
Jan 4, 2016 07:03 AM
72cuttys
Oct 14, 2013 09:30 AM
defiant1
Apr 2, 2011 09:58 AM
davepnola
Dec 2, 2010 09:00 PM
68conv455
May 20, 2008 02:03 PM
