Where is a good vacuum source?
Old June 17th, 2011, 02:14 PM
tdubis's Avatar
Just bought a vacuum gage and was wondering where a good place to hook it up to get readings on timing, carburation, etc... Thanks,
Tom
tdubis is offline
Old June 18th, 2011, 05:55 AM
Tom
The vacuum gauge needs to be connected to a manifold vacuum source. One of the vacuum taps on the intake is your best choice. It's OK to use a tee if needed.
joe_padavano is offline
Old June 18th, 2011, 06:12 AM
70 Cutlass SX
pcard's Avatar
If you are doing this for tuning, could you disconnect the power brake vacuum line and use that as a source?
pcard is offline
Old June 18th, 2011, 08:12 AM
Yeah, but you'll need a reducer to get down to the diameter of the hose on the gauge. It's usually easier to tee into the line for the vacuum modulator if the car has an AT. Also, most carbs have a manifold vacuum port on them.
Old June 18th, 2011, 08:58 AM
tdubis's Avatar
Found it...now what?
Thank-you for the tip Mr. Padavano and Pcard! Found a spot on the intake near the carb. Reading about 18in with a steady vibration up and down between 17 and 19. Could this be caused by the exhaust leak I have at the header gasket? Thanks!
tdubis is offline
69ho aurora
Hurst/Olds
March 26th, 2013 07:55 PM
zodiacblueS
April 30th, 2012 09:52 AM
79Cut2Tone
July 12th, 2011 05:47 AM
Omicron
February 11th, 2010 04:11 AM
Flye
April 19th, 2009 06:33 AM
Quick Reply: Where is a good vacuum source?
