C heads differences...?
Old Jun 16, 2011 | 12:03 PM
STLCRZY's Avatar
Hi.. ,
i ´m in search of a pair of C heads for my 72 455 engine,and i have a few rookie questions.
Is there any differences between the C heads,what must i know.?
How much are they worth?
many thanks
Old Jun 16, 2011 | 12:32 PM
droptopron's Avatar
delete
I believe there were smaller valve versions of C heads used so check the valve sizes.
I could be wrong on this.
Old Jun 16, 2011 | 01:28 PM
TripDeuces's Avatar
So where are you located?
Old Jun 16, 2011 | 01:39 PM
Correct, same basic casting could be machined for either big or small valves.
Old Jun 16, 2011 | 04:56 PM
69442C's Avatar
There were also differences in the heat cross over ports. I have a set of C heads with small cross over ports that are about 5/8" wide by 1 1/4" tall. This is much smaller than the heat cross over ports on another set of C heads I have. Why the difference and was it model specific?
Old Jun 17, 2011 | 05:05 AM
507OLDS's Avatar
If you have the 72 Ga heads from your 72 455,use those.You will not find any differences in performance between the two.
Old Jun 18, 2011 | 01:31 AM
STLCRZY's Avatar
My location is Germany ;-(
About the valves in the C´s:
Intake can be 2.000, or 2.072"
Exhaust are the same 1.625" correct?
About my 72 Ga :
any way to see what valve size are installed without remove the heads and measure it?
thanks
Old Jun 18, 2011 | 10:32 PM
507OLDS's Avatar
You need the head off to measure the valve.
Old Jun 19, 2011 | 04:43 AM
STLCRZY's Avatar
Brian,correct me if i am wrong...my English is not the best.
You say,i don´t feel any significant difference in Performance between the big valves C´s and the big valves Ga´s (the C´s not worth the extra money)?
thanks
Old Jun 19, 2011 | 04:52 AM
cutlassefi's Avatar
Correct. Virtually all of the big valve heads will give similar performance.
Old Jun 19, 2011 | 05:08 AM
STLCRZY's Avatar
Okay...
Mark.
70redvert
Sep 30, 2009 04:31 PM
muad
Jan 19, 2009 03:55 PM
Lady72nRob71
Dec 14, 2008 04:51 PM
musicars
Aug 19, 2008 11:02 AM
texasred
Jul 31, 2007 11:33 AM
