where does this mount???
Old Apr 29, 2013 | 08:54 PM
scooter123's Avatar
Just looking over the wiring in the engine bayon the 71 88 and noticed this little bracket....I dont think I unbolted it on the engine removal.....its attached to the starter wires and one wire the goes down to the trans.
Old Apr 30, 2013 | 07:13 AM
69442C's Avatar
That appears to be a bracket that would install on the driver's side valve cover, last bolt on the upper side. It will accept a clip for the harness that runs down to the starter and the metal tab sticking up will be a support for the metal pipe that runs over to the power brake booster. There is a small spring type clamp that goes around the metal pipe and the tab. If you look closely at the attached picture you can see the bracket and the green clamp.
Brian
Old Apr 30, 2013 | 11:14 AM
scooter123's Avatar
Thanks Brian!!!!!
costpenn
Aug 29, 2018 11:42 AM
Marc A Levy
Nov 4, 2012 07:04 PM
66trifire
Apr 12, 2009 08:50 AM
mcutlass1969
Jul 18, 2006 01:58 PM
JONESY
Jan 11, 2005 09:19 AM
