Where is this coming from?
Hi All,
I looked under my front passenger side area today and found a lot of grease/oil gunk under the car. What is it and where is it coming from? I have no stains or leaks on the floor in that area.
It is behind the radiator and to the side of the engine.
Thanks,
BQ
Thanks,
BQ
Check power steering lines (especially the return line).
Check the transmission oil cooler fitting to the radiator.
Check your steering box for leaks too.
The leak could also be blown around due to the operation of the fan. Check out all the "grungy places" and clean them up. Then monitor, it will show up.
All good advice, but I would say that if this is not a restored car with an obvious wet area, and if its not leaving puddles like a puppy, don't worry about it - you'll drive yourself crazy.
If you ever clean it all up, you can look for a source then, otherwise, let it go.
2001AleroOwner
Alero
Mar 11, 2007 11:21 AM
