whats redline?
Old May 25, 2021 | 05:35 PM
McIntosh's Avatar
whats redline?
Guy's
I just installed new weights and springs in the governer of my TH350 thats behind my recently rebuilt .030 over 455. Full throttle pulls now shifts at 5700 RPM. Seems a little high for my comfort. However it's still pulling hard at that RPM. Whats everyone think a good/safe max RPM is? It's basicly stock valve trane other than springs and lifters. Flat tappet hyd cam.
Old May 25, 2021 | 06:13 PM
If it’s still pulling, I wouldn’t sweat it too much. How accurate is your tach? If it’s a factory tach, it might be much lower than you think.
Old May 25, 2021 | 06:21 PM
McIntosh's Avatar
I think the tach is spot on. We actually ran the wires from a new Innova timing light w built in tach out the hood into the window because I don't trust my tach.
Old May 25, 2021 | 07:52 PM
66SportCoupe's Avatar
Shift
5700 isn't out of line. Don't go much past 6000 without engine mods.
Old May 25, 2021 | 07:53 PM
Shift
Old May 26, 2021 | 05:56 AM
The factory tach might be accurate at idle, I wouldn’t trust it at higher speed. The factory tach wasn’t very accurate when these cars were new. Install a good aftermarket tach, or borrow one just to verify. You might be worried about nothing.
Old May 26, 2021 | 12:40 PM
I like mine to shift at 5000 RPM in Drive, then I can manually shift higher if I want.
Old May 26, 2021 | 10:01 PM
v8al's Avatar
Registered Olds Owner
Curious - What weights and springs did you install to get to a 5700 rpm shift? Just curious how light you went.
Old May 26, 2021 | 11:31 PM
McIntosh's Avatar
I bought a B&M kit. It came with 6 weights. Two each, heavy, med, light. I used one med and one light. It also came with 6 springs all different ranging from heavy to light. I installed the 4th and 5th lightest ones. If I go back in I will use two med weights and the two lightest springs.
I would like it to stay in first longer when under part throttle and shift a little sooner under full throttle.
Old May 27, 2021 | 05:24 AM
I would suggest getting a different governor to play with. That way if you get things really screwed up you can always go back to where you started.
You can change part throttle shift points a couple mph by turning the tiny screw inside the vacuum modulator vacuum hose neck. At most, you will be able to raise or lower the shift points 2-4 mph.
If your going to play around with governor weights, you definitely need a good accurate tach. Make a couple full throttle runs, and record exact shift points. Don’t change anything until you have repeatable results. Change one thing at a time.
Old May 27, 2021 | 05:48 AM
69 Hurst's Avatar
Olds Fanatic
Right, I just went through this. I installed an aftermarket tach temporarily and took the car out. My factory tach was 1000RPM higher then the aftermarket. From what I've read, this is pretty common. I was however able to re-cal the factory tach against the other using the adjustment screw on the back.
Old May 27, 2021 | 03:47 PM
v8al's Avatar
FYI - There are actually 6 different weights included in the B&M Kit (P/N 20248)
Old May 31, 2021 | 08:43 AM
McIntosh's Avatar
correction
Seems V8al is correct. The kit has 6 different weights, not 3 pairs of weights as I thought. They are stamped with a number (1-6) I didn't see with my old eyes. 1 being heaviest 6 being lightest. What is deceiving is that the shape of them does not dictate their weight. What I mean by that is what I thought were 3 pairs because of thier shapes, one of each pair is made of thinner material so is much lighter than its match. I actually used weights #3 and #5. I plan to go back in and change something to bring that shift point down. I don't care for that 5700. Think I should use 3&4 or 2&3? I would be more comfortable around 5200-5400.
Old Jun 5, 2021 | 05:15 PM
McIntosh's Avatar
Update
Today I took the #5 weight out and changed it for #4. I didn't hook up the tach yet but it brought the rpm down a bit. I'm much more comfortable with it now. If I had to guess I bet it's more like 5500 shifts now. I'll post actual RPM when I test with tach.
71OldscutlassS
Oct 8, 2023 05:51 AM
cdaolds
Feb 25, 2020 01:49 PM
mother$hip89
Dec 30, 2018 08:45 AM
mkpola
Jan 6, 2013 01:04 PM
Redog
Dec 29, 2008 06:32 PM
