What are you using for coolant?
Old Sep 1, 2012 | 09:45 AM
scrappie's Avatar
Just got my 71 442 up and running. Its been in storage in my back yard and hasnt been registered since 03. Changed oil, new gas, filters, wires, cap, rotor, tires, brakes. Thinking about changing coolant and want to put something in thats gonna protect against corrosion and low temps when its in cold storage. Is there a product that is better than others and what ratio (coolant/H2O) do you recommend?
Old Sep 1, 2012 | 09:58 AM
50/50% water and Prestone. Then I check it with a gauge to see where it will freeze. It's been in your backyard since 03, and your just wondering now?
Old Sep 1, 2012 | 10:01 AM
Nilsson's Avatar
Prestone color "green" 50/50 distilled water. Somethings never change like coolant recommendations.
This should be good to -20.
Old Sep 1, 2012 | 10:26 AM
Lady72nRob71's Avatar
This is what I use, too. I change it every 4-5 years at the most to keep the corrosion inhibitors fresh.
Old Sep 1, 2012 | 02:00 PM
1970cs's Avatar
Lansing built
Peak with distilled water and set for -35 degrees here in Michigan never reaches that here.
Pat
Old Sep 1, 2012 | 03:02 PM
m371961's Avatar
Whatever you use, mix with distilled water.
Old Sep 4, 2012 | 04:53 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Believe it or not, I buy my Olds' coolant at the Nissan dealership.
http://www.thenismoshop.com/Nissan-f...lant_p_32.html
Old Sep 4, 2012 | 05:10 PM
BILL DEMMER's Avatar
Just the facts...
prestone(green/yellow) or equivalent (farm & fleet brand) 65/35 concentration.
bill
Old Sep 4, 2012 | 05:15 PM
ah64pilot's Avatar
The key is that no matter what brand you use, get the undiluted version of it. Don't buy the 50/50 pre-mixed junk, you are paying for water. Get the 100% antifreeze jug and mix it with distilled water to your own 50/50 ratio.
Here in Texas, I ere to the side of more water than antifreeze...where you are, you might want to ere to the side of more antifreeze than water.
ctrain22
Dec 15, 2009 04:38 AM
ctrain22
Aug 20, 2009 04:47 AM
Rdrokit
Jul 5, 2009 05:11 PM
ctrain22
May 13, 2009 12:55 PM
