What are these ports for?
Old Oct 6, 2011 | 03:58 PM
zodiacblueS's Avatar
Quadrajet for 455 w/ AC,AT,PS,PB. Elec choke. Top left stamped "B", bottom right stamped "H" . Can I just cap them? No EGR or TVSS. Thanks
Old Oct 6, 2011 | 07:38 PM
Lady72nRob71's Avatar
The PCV and evap can ports are labeled right...
OH - the fuel inlet also!
What year?
Old Oct 6, 2011 | 08:09 PM
compedgemarine's Avatar
I will take a shot as this looks to be a mid 70's emission carb. the one with the blue cap goes to the charcoal canister along with the lower one you have marked for that. I think the one in between them also goes to the canister. the other one labeled B with the rubber cap I think goes to the air cleaner for the heat riser control. keep in mind that is a guess from an aging memory as I dont deal with emission stuff much.
Old Oct 6, 2011 | 09:13 PM
77 carb on 73 BB
It's a Holley rebuilt 77 Olds w/ auto (17057256) . Going on '73 w/o emissions crap. No EGR, No catalitic converters, just fuel and fire! Any help is appreciated.
Old Oct 7, 2011 | 04:03 PM
the carb does not know what it is in, only what it was built for. if you are not hooking up any of the emissions stuff then all you really need is vacuum for the trans, power brakes, a/c vents and distributor. you can just cap off anything you dont need.
Old Oct 11, 2011 | 12:14 AM
hotrodpc's Avatar
I do beleive what you have labeled as H is your ported vacuum port that will go to the distrubutor vac advance. Ported vacuum is a dead port at idle. The instant you come off idle the port is now active. Very easy to test that one to be sure. Just put your fingertip over the port and you shouldn't feel vacuum. Give some throttle and all of a sudden you should feel vacuum. This is so that your vac advance is not advancing your initial timing at idle.
RetroRanger
Aug 20, 2013 11:51 AM
DAN76
Jun 24, 2009 01:43 AM
MN71W30
Apr 2, 2009 08:33 PM
The Pope
Sep 24, 2007 05:29 PM
blonzz
Sep 27, 2004 10:54 AM
