Blocking exhaust crossover ports on intake?
Old Sep 3, 2004 | 04:49 PM
blonzz's Avatar
Post
What is the best method for blocking off the exhaust crossover ports on a BBO Torker intake manifold?
I understand that just installing the supplied cast iron plugs will cause rattling and doesn't completly seal also.
Thanks,
John
Old Sep 25, 2004 | 05:03 PM
powerplant455's Avatar
Angry
I know this has nothing to do with your question, but did you know if you block off your crossover it makes your engine louder.
Old Sep 27, 2004 | 10:54 AM
Oldsguy's Avatar
Past Administrator
Post
There has been a LOT of discussion on this subject over a ROP. You should check it out. There are apparently two kinds of material that can be used to fill the crossover, some people like one kind and others like the other kind (aluminum from old pistons and a zinc material from somebody like Mondello). I don't know as I havene't done it. I know that everyone that has used plugs agree that they will rattle with time. Whatever you do, good luck in the endeavour.
rmoths
Sep 3, 2012 04:40 PM
KQQLCAT
Jan 11, 2011 09:43 AM
cts-v
Oct 21, 2010 07:12 PM
captjim
Sep 23, 2008 05:21 AM
shaks 442 clone
Mar 29, 2008 08:31 PM
