425 vs 455 and 330 vs 350 Damper Bolt Torques ??
Anyone got the lowdown on torque values for damper bolts on '65 - '67 motors vs '68 - up motors?
In the manuals for '65, '66, and '67 the torque is specified as 50 ft/lbs.
In the manuals for '68 and up the torque is specified as 160 ft/lbs minimum.
There is no discernable difference between the crank ends, dampers, or bolts.
I would ASSume that the change is not because anything about the engines changed, but because GM realized the old spec. wasn't enough.
Do I ASSume correctly?
Any juicy stories from the old days behind this one?
Of course, if you wait to do this until AFTER you take the engine out you're back to a mile long cheater bar and 4 friends to help lol!
Early 65 cranks had a smaller bolt, hence the lower torque. Olds found some issues with the bolts loosening so went to 3/4 fine thread bolts (1.125" head) in mid 1965 iirc. It took time for the service manuals to catch up. All the big bolts are taken to 160 ft lb.
Okay.
So they changed the bolt in '65, but they didn't change the manual till '68.
Typical, no?
There must be a service bulletin saying, "Ignore the manual - just torque it to 160."
Thanks for that.
It makes sense, and I knew there would be some kind of a story.
Typical, no?
Thanks for that.
