What are the real hp and torque ratings of 455 motors?
Old August 28th, 2009, 10:56 AM
nickd's Avatar
Are the horsepower ratings true or not? The older 455 ratings seem right but did they rate the newer ones(72-76) @3000 rpm? What were the actual ratings @ 5000 rpm?
nickd is offline
Old August 28th, 2009, 05:35 PM
72 cutlass455's Avatar
Most of the engines were purposely rated below the actual hp and torque to ensure they could meet the stated rating posted for them.
72 cutlass455 is offline
Old August 28th, 2009, 08:02 PM
zed
zed's Avatar
Wasn't it from '71 on that they started rating them in net HP? As opposed to gross HP.
zed is offline
Old August 29th, 2009, 01:19 AM
They differ from car to car but will be in the stated ratings. They truly mean nothing as the only measurement that counts is how many you are putting on the road and can only get rear wheel hp and torque from a dyno.
Old August 29th, 2009, 01:27 AM
http://www.442.com/oldsfaq/ofeng.htm#ENG 1964 - 1990 Engine Performance does not say when there system was changed.
Old August 29th, 2009, 04:29 AM
MN71W30's Avatar
If you do the math. My 68 W30 was rated at 360 HP it ran a 13.9@97MPH on a perfect day, it's closer to 325 HP. If a 70 98 Olds had 365 HP it should run in the low 14's, they might run a mid 15 sec 1/4 mile at best.
Some motors were closer than others.
MN71W30 is offline
Old August 29th, 2009, 08:00 AM
nickd's Avatar
The 98 was alot heavier tho wasn't it. Did they rate them @ 3000 RPM because of insurance in the 70's?
nickd is offline
Old August 29th, 2009, 08:10 AM
Proud Viet Nam Veteran
redoldsman's Avatar
It was 1972 when they changed the way horsepower was rated. If I remember correctly, it was rated off the back of the transmission with a closed air cleaner and exhaust.
redoldsman is online now
Old August 29th, 2009, 08:49 AM
Registered
Bluevista's Avatar
According to the article in the link below the early "gross" ratings were taken with a basically bare engine with open headers and optimized timing. The later "net" ratings were acquired with all the accessories and exhaust in place, stock ignition timing. Both were taken at the flywheel with the engine on a test stand.
The HP numbers weren't written in stone, that's for sure. Just about whatever they needed them to do they did.
http://ateupwithmotor.com/terms-and-...orsepower.html
Bluevista is offline
Old August 29th, 2009, 08:53 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
68-76 Olds 455 HP rating: Not enough.
J-(Chicago) is offline
Old August 29th, 2009, 09:27 AM
citcapp's Avatar
Is there such a thing as to much hp. Me thinks not
citcapp is offline
Old August 5th, 2017, 05:01 PM
MudEye's Avatar
That car looks like a big mouth bass........
MudEye is offline
Old August 5th, 2017, 05:12 PM
Tedd Thompson's Avatar
Look at the date on his post, RIP Pat. This always makes me sad when a post comes up on a lost friend..... Tedd
Tedd Thompson is offline
Old August 5th, 2017, 06:41 PM
Gary M's Avatar
Here's mud in your eye
unintentional but ironic. So many old threads get resurected. Inevitable I guess.
Gary M is offline
Old August 6th, 2017, 03:20 PM
ph_ckstick1
midnightleadfoot's Avatar
It happens when a person uses the search ..
Forum banter
" used search" gets reply this thread id 2-3-4-8 years old
"post a thread" gets reply use the search, it's been covered..
lol
midnightleadfoot is offline
Old August 6th, 2017, 05:39 PM
oldsmobiledave's Avatar
Fyi
'71 saw both Gross & Net hp ratings, '72 & newer were Net only.
oldsmobiledave is offline
Old August 6th, 2017, 05:44 PM
MudEye's Avatar
Much Apologies......Was just browsing.....No intended offense...But it looks like a big mouth Bass! I'm sure He knew that! What a great car! Why kill an old thread? I'm trying to turn on as many young folk as possible to the olden days, olden cars, and those pictures are classic! You should be happy.....cause I am...for the pictures and the thread!
MudEye is offline
Old August 6th, 2017, 05:50 PM
MudEye's Avatar
Sorry ....but you know what......The old threads are good!.....I love reading them! I am not so good as to navigate thru the new ones.....I love reading the old threads.... I have learned so much........
MudEye is offline
Old August 7th, 2017, 08:38 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Some pass on, which is sad, others like J- Chicago just disappeared.
olds 307 and 403 is offline
Old August 8th, 2017, 01:45 AM
Kennybill's Avatar
Reviving old threads isn't a bad thing. It gives one a chance to reflect on former members. In some cases you never know if they passed away or just moved on from Oldsmobiles. The threads topic still sparks interest today after all these years. Let's hope the next time this thread gets renewed someone's not asking what happened to one of us.
Kennybill is offline
Old September 9th, 2017, 08:19 PM
VinMichael's Avatar
I hope to finish my car before I pass away. Everything seems to want to get in the way of getting it to where I want it.
VinMichael is offline
Old September 10th, 2017, 08:40 AM
brownbomber77's Avatar
J-(Chicago)
Yeah....actually...where did he go...?
brownbomber77 is offline
johnnyquick
September 22nd, 2023 09:17 AM
79MKII
July 31st, 2015 04:42 AM
MDchanic
October 22nd, 2011 05:57 AM
Rocket Richard
June 11th, 2011 11:07 AM
geckonz08
Tech Editor's Desk
April 26th, 2011 03:14 PM
Quick Reply: What are the real hp and torque ratings of 455 motors?
