What is this part
Old Sep 3, 2013 | 03:53 PM
Raydermiike's Avatar
What is this part
What is this round part with the prongs? and why is nothing connected to it?
Old Sep 3, 2013 | 04:08 PM
442Harv's Avatar
More info what type car and year?
Old Sep 3, 2013 | 04:15 PM
66luvr's Avatar
That is a switch to control a switch pitch converter and "kickdown" for the transmission. Sort of looks like a 65-6 Delta or some big car, just a wild guess.
Old Sep 3, 2013 | 04:18 PM
The car is a 67 Cutlass with what I am finding to be a 67 Toro engine. It isn't hooked up yet the transmission shifts fine and it does kick down when stepped on.
Old Sep 3, 2013 | 04:22 PM
tru-blue 442's Avatar
Old School Olds
That is the bell-crank. Looks like 66-67 Cutlass.
Similar to the one on my 66. 66luvr is correct.
There is a pigtail that goes to the transmission
for it to kick down.
Old Sep 3, 2013 | 04:26 PM
The transmission kicks down though the bell crank is unconnected. Would the fact that there is a non original T-350 tranny instead of the original 2 speed render the part not needed?
Old Sep 3, 2013 | 04:32 PM
Old School Olds
It would now just be needed for the throttle
to operate.
Does the 350 have a cable coming up to the
carb and attached? That would be the only
way the 350 could kick down automatically.
I would be interested to see how the hooked
that up too. Any more pics?
Old Sep 3, 2013 | 04:35 PM
jeffsims's Avatar
1967 442
Look on the driver side of the transmission. Somewhere around the speedometer cable connection you will see a plug with a 2 wire cable. This cable connects to the kickdown module on the throttle linkage.
Old Sep 3, 2013 | 04:38 PM
There is a cable coming up to the carb. Thanks for your help, everyone on this board is awesome.
Old Sep 3, 2013 | 04:41 PM
Old School Olds
Mike could you post a pic of
the cable attached to your carb?
I am curious to see which bracket they used.
Old Sep 3, 2013 | 04:52 PM
jag1886's Avatar
Not needed with a 350.
Old Sep 3, 2013 | 05:07 PM
What you are looking for I think for the cable linkage.
Old Sep 3, 2013 | 05:09 PM
There is this single connector I found homeless but no clue from where or for what.
Old Sep 3, 2013 | 05:19 PM
Old School Olds
That one is the powerup
to the bellcrank, the spade on
the left. The pigtail connects
to the two spades on the right.
Thanks for the pic, just what I was looking
to see. Looks like they used a late model bracket
from a 80's something Delta or so.
Old Sep 3, 2013 | 05:36 PM
I am at loss as to the pigtail but will look further. Is it pointless to hookup anyway since it has the automatic kickdown
Old Sep 3, 2013 | 05:44 PM
Old School Olds
Exactly, you don't need it.
You could use the orange wire
for a later model hood light with
the mecury switch if you wanted.
Old Sep 3, 2013 | 10:03 PM
svnt442's Avatar
Duh...that's a rod..not a cable.
Old Sep 3, 2013 | 10:20 PM
I believe the part in question is the cable below the rod. In any case if your best answer is Duh I'll look to someone else for help.
Old Sep 3, 2013 | 10:22 PM
svnt442's Avatar
I was actually saying that about a post I deleted....in case it hit someones email. I couldn't figure how the carb was even working and then I realised after I posted that this is a 67 and that's a rod, not a cable.
Notice that the cable bracket is empty....I was a bit stumpped and then the light bulb went off.
Old Sep 3, 2013 | 10:33 PM
Not sure what you mean but if it was a mistake please forgive my response.
Old Sep 3, 2013 | 10:34 PM
svnt442's Avatar
Yeah it wasn't meant to be at you. Sorry about that.
IZAOLDS
Aug 9, 2010 08:36 AM
kjr442
Feb 22, 2010 06:45 AM
Texas Jim
Ninety-Eight
17
Dec 30, 2009 06:28 PM
deweirdt
Jul 21, 2009 08:29 AM
