What is a good 4bbl intake to use on 1973 455?
Old May 19, 2016 | 05:37 AM
Almond900's Avatar
I finally found a good 455 for my cutlass, donor car is a 1973 Delta 88, 67,000 miles and runs excellent. So my plan is do a timing chain, a gasket set and put a 4 bbl before it goes in, I can't seem to find any iron 4bbl intakes close to me, and shipping would be ridiculous because the wieght. Any suggestions on a decent aftermarket? Other than dual exhaust the motor is staying a stock
Old May 19, 2016 | 05:55 AM
An Edelbrock Performer is a good stock replacement.
Old May 19, 2016 | 06:20 AM
Almond900's Avatar
I did find a Holley street dominator intake at a shop just down the road but I don't know much about Holley intakes, any thoughts on them?
Old May 19, 2016 | 06:33 AM
It depends on what you intend to do with the motor and car. The Street Dominator is a single plane intake like an Ebrock Torker. Good for high-RPM HP, but not so good for low end torque on the street. A relatively stock 455 in a Cutlass for street use will be MUCH happier with the Performer.
Old May 19, 2016 | 06:50 AM
Run to Rund's Avatar
check with John Stolpa at Rocket Racing in WI; he might know of some take-off iron intakes.
Old May 19, 2016 | 06:57 AM
Almond900's Avatar
Thanks Joe, it's just a weekend toy, no racing or high rpm stuff, usually it just goes out to dinner on Saturday night and an occasional car show on Sundays. I did find a 68 cast iron intake on Craigslist about 45 minutes from me but I haven't heard back if he still has it, the posting was a month old
Old May 19, 2016 | 06:59 AM
Be aware that the 68-69 intakes are set up for the divorced choke coil, not the hot air coil used on the 1970-later carbs. If you do use a 68-69 intake, you'll need to use an electric choke on the carb. Note that you may want to do that in any case.
Old May 19, 2016 | 07:03 AM
Almond900's Avatar
Thanks I'll check out rocket racing
Old May 19, 2016 | 07:12 AM
oldsmobiledave's Avatar
Fyi
Put an Edelbrock Performer on it. Done.
shamusj
Dec 18, 2014 09:28 AM
JpMotorsports
May 15, 2014 07:08 AM
507OLDS
Oct 18, 2012 07:56 PM
philnjean
Feb 10, 2011 06:53 AM
Oldsguy
Apr 27, 2009 11:45 AM
