What causes this?
What causes this?
Look at the stamping block to the front and below the #1 plug. If the block is a 72, the engine stamping will start out 32(L)XXXXXX, where:
3 - Oldsmobile
2 - model year production
(L) - letter could be M, F, Z, R which represents the factory it was produced
XXXXXX - is the last 6 digits of the VIN# of the car it came from.
I work in the engine parts business. I remember once visiting a machine shop customer up in the Midwest who had a Chev. 2.8 V-6 on an engine stand in his waiting area to display to his customers the value of changing the oil. It was so "congested" under the valve covers that it looked like a giant slab of gray Velveeta that had taken the form of the valve cover. The rockers had just enough room to move up and down. I still don't know how any oil could have possibly returned to the pan that went to the top of the motor.
...It was so "congested" under the valve covers that it looked like a giant slab of gray Velveeta that had taken the form of the valve cover. The rockers had just enough room to move up and down. I still don't know how any oil could have possibly returned to the pan that went to the top of the motor.
I have seen a couple like this back in the day. One was my Grandfathers 1964 Plymouth. He changed the oil regularly but insisted that Quaker State 30 wt Non detergent oil was the best made. I pulled the valve covers to replace the gaskets and they looked like that valley pan. Several years later I ran into another just like it in a Chevy either 327 or 350. Asked the customer what kind of oil he used and he proudly stated he never used anything but Quaker State NON DETERGENT,
All I can say is Wow! No oil changes or?? I ran Quaker State back in the day in I think 3 Chebbies and they all foamed white sludge at the oil filler cap. And yes, I did change the oil regularly.
That's what non-detergent oil engines looked like. I've seen the valve covers area full of waxy carbon crude. Just channel to the oil return holes. We would burn the crude out of the valve covers to clean them. We went by the "once an engine had non detergent oil used, detergent oil would ruin it." I'm surprised because by 1972 non detergent oil wasn't used in new cars anymore. Even though it's ugly, it might surprise you by having decent worn bearings. As long as the crude was disturbed engines lasted but not like the more modern oils. Ken
That's what non-detergent oil engines looked like. I've seen the valve covers area full of waxy carbon crude. Just channel to the oil return holes. W[I][/I]e would burn the crude out of the valve covers to clean them. We went by the "once an engine had non detergent oil used, detergent oil would ruin it." I'm surprised because by 1972 non detergent oil wasn't used in new cars anymore. Even though it's ugly, it might surprise you by having decent worn bearings. As long as the crude was disturbed engines lasted but not like the more modern oils. Ken
When I was a young fella I watched a mechanic changing the oil on a diesel Land Cruiser. He was using a piece of Bent wire to pull it out of the sump plug!! It looked like he made it to blow bubbles!
Needless to say im very aware of regular services.
Checkov
February 18th, 2015 12:41 PM
russell-t
May 10th, 2012 05:38 AM
