Weird noise from back of engine
Old Jan 30, 2024 | 09:48 PM
  #41
cjsdad's Avatar
I rolled a '68 VW bug twice over sideways and once over end-to-end. Trans stuck in 3rd - no clutch. Drove it 30 miles home and parked in front of my folks yard. Mom was alarmed. Popped all the windows out, roof crushed had to exit via the windows.
So, telling someone else that they are "dead in the water" and will have to be towed because their throw-out bearing has failed is a straight up, bald-faced lie! You are obviously not the only one that can get home if something on their car breaks so quit being such an alarmist.
Telling someone their throw-out bearing can fail if they neglect it is good advice. Telling them they are too stupid to drive home if it does fail is arrogant and false.
Old Jan 31, 2024 | 06:10 AM
  #42
Dynoking's Avatar
I suggest a careful inspection of the release fork, the ball stud, the Z bar, the engine mounted Z bar ball stud and corresponding chassis bracket, the clutch pedal pivot bushings, and the clutch pedal and release lever push rods.
It has been my experience that many if not all of these components will be worn and require replacement after 50+ years of service. If you do reuse any of the components a through cleaning and lubrication of all friction points will restore the clutch system to like new performance.
rket56
Nov 10, 2021 06:27 AM
piperman60
Mar 16, 2018 08:45 AM
Professur
Feb 9, 2014 02:14 PM
Allan R
Jul 18, 2011 09:43 PM
442 Guatemala
Jan 27, 2009 10:12 PM
