Wear in block where distributor runs goes
Old May 3, 2025 | 02:54 PM
gtucker's Avatar
gtucker
Someone did not put right plug in back of block to oil cam gear and distributor. Now looking at block it has a lot of wear where the distributor sets. It has some deep grooves. What is the fix if any putting new cam and distributor in it. Oh yet and right plug Any help will be appreciated
Old May 3, 2025 | 03:59 PM
fleming442's Avatar
I wouldn't worry about it in the block if the distributor shaft is good with proper amount vertical play (minimal).
Old May 3, 2025 | 07:05 PM
Run to Rund's Avatar
I have used a brass washer as a shim with a worn block.
sshriber
Feb 16, 2023 08:05 AM
Olds 65
May 21, 2021 07:58 AM
foo
Jun 26, 2017 06:25 PM
body 51
Nov 7, 2011 07:43 AM
scott_442
Oct 8, 2008 09:41 AM
