water valve on intake ?
Old Sep 1, 2009 | 03:43 AM
bullet1's Avatar
not sure what its called but the water valve on back of intake that goes to the heater and controlled by vacuum is this still available and what is it really called? mine is leaking into vacuum line.
thanks
Old Sep 1, 2009 | 05:19 AM
Lady72nRob71's Avatar
What year and model?
It is called a "heater valve" and for a 72 Cutlass, they are available at Napa and other local shops. Rockauto should have them also online.
Old Sep 1, 2009 | 05:54 AM
I bought a new one at O'Reillys for about $25. It was in their computer under "heater core."
Old Sep 1, 2009 | 06:28 AM
bullet1's Avatar
i have 68 442 i will give napa a call
thanks
Old Sep 1, 2009 | 06:15 PM
O's_Car's Avatar
Also available at Supercars Unlimited, but a bit pricey (especially for '68 V8s).
www.supercarsunlimited.com
Old Sep 1, 2009 | 07:15 PM
bullet1's Avatar
stopped by napa today they didnt show one for 68 but did for 70?i thought they were all the same?of course they didnt have one on hand ill have to try someplace else.
Old Sep 1, 2009 | 11:33 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
68-70 should be the same.
They are not all alike. Some the vacuum holds them open, and some the vacuum holds them closed.
Those things are stupid. I have provided a diagram to help you fix your problem, and keep 75 dollars in beer money.
Old Sep 2, 2009 | 02:30 AM
bullet1's Avatar
looks like a good idea ill cut it off tonight
thanks
Old Sep 2, 2009 | 06:06 AM
Don't bother cutting it off. You can go to your local hardware store and get a brass nipple to fit that size pipe thread. It will cost aobut $10 but it will fit the threads and it will have a serrated male fitting so you can put a heater hose on it.
Old Sep 2, 2009 | 06:28 AM
bullet1's Avatar
talked to napa guy last night about doing just that.happen to know thread size off hand otherwise ill take off and bring with me.
thanks
Old Sep 2, 2009 | 07:49 AM
Those threads are different sizes for different intakes as well. My guess would be a 1" npt.
I'm going to have to disagree with Oldsmobrother64, and recommend you just hack it off on car. Less wrenching, and less trips to the hardware store. If you try to twist it out as a whole unit, it'll probably just break or twist up the pipe.
Old Sep 2, 2009 | 08:53 AM
J does have a point. If you hack it off it would be cheaper too. I have one of those frozen solid on the intake of my 455 that came out of my 71 98. I tried a cheater bar, PB blaster and vise grips. It is stuck. So, I just bought a new one for the engine that went in my car.
Old Sep 3, 2009 | 05:43 AM
mugzilla's Avatar
is Fast Enough ...
I bought one that was a 1/2" taller than stock so check out any clearance issues when you replace ...
jensenracing77
Mar 19, 2014 04:08 PM
svnt442
Jul 17, 2011 04:43 PM
oldspackrat
Apr 20, 2011 07:08 PM
1973olds98
Dec 15, 2010 04:39 PM
rhett838
Aug 25, 2010 07:01 PM
