water temperature
Old Feb 20, 2011 | 05:39 AM
olds67's Avatar
water temperature
Hi Guys
yesterday when I felt my Olds, I noticed that the temperature was still 210 F.
it is normal that it is so high?
The thermostat I got was 180 F
Old Feb 20, 2011 | 05:53 AM
Rickman48's Avatar
If you've a 180 thermostat, it should run @180!
After shutting it off, you're not pumping coolant, and it'll go up -
If it's running @ 210, your cooling system might need a good flush, the radiator's clogged, or the lower hose is collapsing - should have a spring in it, to hold it open!
Thermostats go bad, too!
Could aso be lower octane gas, but you shoud get 'pinging' when accelerating - try premium gas!
Old Feb 20, 2011 | 06:06 AM
olds67's Avatar
I try and do some checks.
The radiator is new.
I may have taken too long time the engine running when stationary?
yesterday there were like 30 F outside temperature.
Old Feb 20, 2011 | 06:23 AM
Lady72nRob71's Avatar
At 30*F ambient temp, it should run at thermostat temp all the time. It should idle "forever" at that temp, too.
My WAGs are: wrong timing, bad thermostat (I have been gifted with many defectve ones right off the shelf...)
and/or bad fan clutch. If it runs normal temp when on the highway, this might be it.
Old Feb 20, 2011 | 06:28 AM
olds67's Avatar
I have not managed to prove the car for a long time on the road for a few minutes at home or in the parking lot, where I can hold on and I would not want it too hot.
During the week I do a bit of evidence
Old Feb 20, 2011 | 06:30 AM
olds67's Avatar
better to put a thermostat lower and then do another test?
Lady72nRob71
Oct 6, 2019 07:24 AM
tpawlik
May 16, 2011 05:06 PM
nelsontj
Care and Appearance
Oct 14, 2009 03:09 PM
Oldsproject
Jun 15, 2007 08:52 AM
<john f>
Jan 3, 2004 11:19 AM
