Water pump and accessory brackets
Old Jun 3, 2014 | 11:19 PM
rpinnt's Avatar
Can anyone tell me if the alternator & power steering brackets from a 1965 330 will bolt onto a 455? I am building the 455 for the swap and it looks like I will need a new water pump. I am wondering about the proper water pump length (non a/c car.) If the 330 brackets won't fit I may have to look for a proper matched set.
Old Jun 7, 2014 | 09:20 PM
Octania's Avatar
Sort of.
non-AC RH side alt brackets for a '65 330 I believe are small block specific.
Later RH alt brackets will do you though
with AC, it gets complex real fast
If you get the same length WP that the 330 had then the same 330 pulleys will line up on the later engine. You will have to have the pre-68 PS pump and its brackets to go with. Use the 330's PS Pulley on the 330 PS pump of course.
68 D88
Feb 16, 2015 05:20 AM
olddaz
Aug 27, 2014 06:39 PM
QS442
Nov 23, 2013 07:45 PM
Mocephus
Dec 2, 2012 09:46 AM
pontiac1
Dec 24, 2009 07:25 PM
