VIN # location on block
Old Mar 6, 2011 | 01:33 PM
Chumley's Avatar
I forget where the pad on the block with the unit # is located on big blocks. Is it in the same location as small blocks? Trying to determine if a car for sale is numbers matching. Thanks, Chumley
Old Mar 6, 2011 | 04:11 PM
svnt442's Avatar
Yup. Same location just below #1 spark plug.
Old Mar 9, 2011 | 01:13 PM
blueRAYwhale's Avatar
Smile ...? VIN-tage
here's a simple yet possibly overlooked ID thing. check the oil fill tube, the first # is the year of manufacture. i think there is like eight #'s in a sequence. sometimes they are facing backwards, or dirty and it's hard to read them. possibly won't help because the fill tube might of be removed/replaced.
Old Mar 9, 2011 | 02:53 PM
Originally Posted by blueRAYwhale
here's a simple yet possibly overlooked ID thing. check the oil fill tube, ...possibly won't help because the fill tube might of be removed/replaced.
Which is exactly why we have "overlooked" this intentionally.
Old Mar 9, 2011 | 03:15 PM
check the tube, it's a start
quit trollin', just tryin' to help a dude out. it says numbers matching, so the tube should say 8 or 9, if it says 1 then it isn't from a '68 or 9.
Old Mar 9, 2011 | 03:22 PM
The fact that the number on the oil fill tube shows the correct year doesn't contribute anything to a "numbers matching" claim, because it doesn't match any other number on the car. The VIN derivative on the block is the only number if concern to verify numbers matching for that year. One could have a numbers matching block with a switched oil fill tube.
Don Bunnell
May 8, 2020 02:15 PM
jordan479
Jul 26, 2016 06:34 AM
metalmen
Aug 16, 2012 02:05 PM
justinj
May 7, 2012 10:55 AM
NastyNate6695
Jan 1, 2012 11:49 AM
