valve cover gaskets
Old Nov 10, 2008 | 06:50 AM
miho35o's Avatar
valve cover gaskets
Is it a major undertaking to change valve cover gaskets on a '76 98? I am an amateur and have only done things like oil, brakes and plugs. i would like to learn to do more but is this something that is a bit out of my beginner range?
Old Nov 10, 2008 | 07:03 AM
citcapp's Avatar
Easy job,
1. If you have never done this before, take pictures of the engine bay as you take things apart.
2. remove air cleaner detach hosed and items from the valve covers. and buy new gaskets
3. remove all of the bolts from the vlave cover. Using a medium screwdriver pry the covers loose. tap on the covers with a rubber hammer to help loosen the covers.
4. using a scraper and chemical gasket remover (Use spray onmn from any auto parts storp. Remove all of the old gasket from both the head and the valve cover.
5. turn the valve cover so the underside is facing up and lay the edge were it bolts down on a flat hard steel surface. The back side of a vise works well. usind a small habber and a socket extension tap the area around the bolt hole flat.
6. check the valve train while you have the covers off for debis and make sure yopu scrape out all of the gunk.
7, install the new gaskets on the valve covers with some gasket sealer and reinstall the covers. Snug down the bolts and tighten 1/4 turn. Do not over tight or they will leak
8. Using the pictures re-assemble everything and your are done
Good luck
Old Nov 10, 2008 | 10:37 AM
I would be wary. That is a pretty tough job.
Old Nov 10, 2008 | 11:51 AM
citcapp's Avatar
Jesse,
Your kidding of course!!!!!!!!!!!!!!!!
Old Nov 10, 2008 | 01:22 PM
Old Nov 11, 2008 | 10:49 AM
tonycpe's Avatar
You may also wany to recheck the bolts after a couple engine heat cycles.
Old Nov 12, 2008 | 05:41 PM
Redog's Avatar
I strongly suggest spending the extra few bucks and buy the reuseable valve cover gaskets from Summit.
I bought a set for $25 or $30 and you do not need RTV to install and it's impossible to over torque the bolts
Old Nov 12, 2008 | 07:54 PM
88 coupe's Avatar
Junior Member
Originally Posted by Redog
........ and you do not need RTV to install ........
Unless the covers have been damaged, there is no reason to use RTV.
Clean mating surfaces and proper torque (7lbs) are a given.
Norm
Old Mar 28, 2009 | 09:41 PM
Yellowstatue's Avatar
Smile Gaskets
I think Citcapp missed a big clue here ('76 98) that car would more than likely have A/C which means that all those goofy slingshot looking brackets have to come off first, alt and comp, and then....begin the list with easy!!
Ddbord
Apr 12, 2012 06:50 PM
Jannebill
Oct 13, 2010 11:55 AM
Aceshigh
Mar 27, 2010 08:36 AM
miho35o
May 24, 2009 04:32 AM
dallas6778
Nov 20, 2007 10:04 AM
