Valley pan question
Old May 18, 2012 | 05:24 PM
Bugg's Avatar
Valley pan question
Just like everyone said, the rubber seal squished out, so I have to redo it. Good idea to try and reuse the pan or is it shot after it gets torqued down?
Old May 18, 2012 | 05:34 PM
tru-blue 442's Avatar
Old School Olds
The pan is a compression gasket.
Once it's used, it's done. I have done the
same thing though.
Old May 18, 2012 | 07:53 PM
I've long suspected that most of the problems that people seem to have with the metal intake gasket come from trying to reuse it. The beads around each port are designed to crush to achieve the seal. The gasket cannot be reused reliably.
Old May 19, 2012 | 05:34 AM
Bugg's Avatar
Figured so just by looking at it out of the box, oh well, already ordered a new one and some other stuff...guess I'll go without the end seals
Old May 19, 2012 | 06:00 AM
Old School Olds
What I have done in the past to get away from those
pesky end seals, I drilled 3 small holes at each end of the block
where the seals fit, two just off the ends, and one in the middle,
and used silicon. I set the manifold down, just started the bolts,
and walked away for an hour or so. Came back tourqed them down.
Retourqed about a week later. All was good.
Not saying this is the way to go, but it worked for me.
1973olds98
Oct 31, 2010 03:50 AM
rtpassini
Apr 25, 2010 06:41 PM
Flye
May 12, 2009 05:30 PM
mcutlass1969
Oct 25, 2007 05:00 AM
mcutlass1969
Jul 12, 2007 04:55 AM
