Tuneup talk
Old May 22, 2024 | 06:06 AM
  #41
Originally Posted by ourkid2000
The spec on mine is 7.5, is it safe to try 10-12?
It's a good question to ask whether it's safe. I'd hate to tell you it is safe purely based on advancing initial timing alone. The cat pi$$ they sell as unleaded gasoline today is not the same as the leaded (high octane) gasoline's they sold in 1966 & you can expect variation(s) in performance based on timing alone. Mid-to-Late 60s we were buying low grade regular leaded gasoline with an octane level of 93. Premium grade was ~99 octane - yeah, big difference in fuel in 60 years of petroleum gasoline. I'd try bumping initial to ~10°.
droldsmorland provided some excellent suggestions Post #16
Old May 29, 2024 | 04:40 PM
  #42
ourkid2000's Avatar
Well, I've made some progress with this (I think). I got thinking about it and I had a feeling that something was going on with the primary rods.....like maybe the wrong power piston, spring, or rods was installed. This is a bit of a frankencarb after all (it's my backup carb while I get my original restored).
Took it apart today and sure enough, wrong primary rods. It is supposed to have 44 rods, it has 49B rods installed instead, Everything else appears right. I will install the spare set of 44 rods that I have and report back!
Old May 30, 2024 | 10:15 AM
  #43
ourkid2000's Avatar
Yes sir! That's what it was.......replaced the 49B's with 44's and it runs like a champ!
Old May 30, 2024 | 01:13 PM
  #44
Mikeyt's Avatar
Mikeyt
Nice!
Glad it worked out
Old May 30, 2024 | 02:47 PM
  #45
Excellent.
Old May 30, 2024 | 03:06 PM
  #46
ourkid2000's Avatar
Excellent.
Still has a slight bounce on that vacuum gauge though (less than 1/2 of 1" of Hg while at 18"). Might be a valve sticking? Bad plug wire? Bad plug? All I know is it isn't rock solid.
Old May 30, 2024 | 03:18 PM
  #47
Check spark plug number, condition & gap.
68_Cutlass_S_Convertible
Jul 29, 2023 12:49 PM
old greybeard
Oct 7, 2021 09:17 AM
coppercutlass
Apr 15, 2018 07:25 AM
n_holman
Oct 5, 2014 11:38 AM
Arrowstorm
Jul 8, 2014 11:59 PM
