Which trans fluid for my '66 toronado?
Old Mar 12, 2022 | 11:37 AM
'66toro's Avatar
Changing fluid (and filter) in my ’66 Toronado and wondering if using Valvoline Max life synthetic fluid is acceptable for this transmission? It is a multi-vehicle blend, for GM Dexron II, III, and IV etc. Some say using synthetic fluid in older transmission can cause leaks so wondering what others have to say about it? Also, is it safe to add it to what old conventional Dexron does drain out?
n’t drain out in during the change?,,,
Old Mar 12, 2022 | 01:05 PM
rocketraider's Avatar
Oldsdruid
I would put Dexron III/Mercon in it if you can find it.
I would stay away from anything synthetic unless the transmission has been recently rebuilt with parts compatible with it. Contrary to what a lot of folks say synthetic isn't compatible with 60s vintage clutch materials.
Old Mar 12, 2022 | 01:17 PM
'66toro's Avatar
Thanks for your reply. I read many places that the Ford F type fluid is a good replacement for the Dexron III,,,
Old Mar 12, 2022 | 01:51 PM
Oldsdruid
Again, ONLY if the transmission has been rebuilt and is dry before you put the Type F in it. F has different friction characteristics than Dexron or any synthetic and may not mix well with any existing Dexron in the transmission.
Old Mar 12, 2022 | 02:55 PM
A lot of people use Type F, it can be mixed with Dexron. It will firm up your shifts.
Old Mar 12, 2022 | 05:49 PM
Oldsdruid
Did that in a couple of high-mile Turbo 350s with no ill effects.
Tried it in a Toronado's 60k mile 425 and immediately after the drain and refill with Type F the 2-3 shift went from quick and positive to a drawn-out shift with engine flare. Coincidence? Maybe. But I've been wary of mixing different fluids since then. A 425 was a $1300 rebuild in 1990.
Old Mar 12, 2022 | 09:09 PM
It will work fine.
Gesr changes are accomplished by hydraulically clamping friction plates together. As long as the pump can provide enough pressure, and the friction material has enough surface area to provide sufficient grip, the type of fluid has little influence.
The fluids purpose is mainly cooling and the pressure. And I have never put too much faith in the mixing of conventional and synthetic fluid causing leaks.
Old Mar 13, 2022 | 08:49 AM
Charlie Jones's Avatar
Phantom Phixer
Stick with Dexron III / Mercon.
It's what this transmission was built to use, and is a safe bet.
Anything else is a crapshoot.
Old Mar 13, 2022 | 02:01 PM
'66toro's Avatar
Even though I have 3 gal. of the multi-vehicle Valvoline in stock for other vehicles and also several quarts of Ford F type for my old Thunderbird, all things considered it sounds like sticking with Dexron III is the safest bet,,,thanks to all made suggestions!
JVCCutlass
Aug 8, 2021 03:59 PM
jpatfarrell
15
Nov 24, 2018 03:30 PM
Zacc
May 5, 2018 08:27 PM
Franswa
Oct 8, 2017 01:32 PM
jpc647
Jun 24, 2014 10:11 AM
