Torque sequence and specs
Old Jun 24, 2013 | 12:29 PM
ctreutel's Avatar
Hi Guys;
I'm about to reassemble my 1976 455. I have a 1969 chassis service manual with all the specs...but I want to be sure the torque specs and sequence for the heads, rods, intake, etc...is all the same from 1968-1976 on the 455 engine.
Old Jun 24, 2013 | 01:51 PM
cutlassefi's Avatar
Stock bolts on everything? If so then follow the service manual.
Old Jun 24, 2013 | 02:01 PM
ctreutel's Avatar
Yes...stock bolts for the most part. If I do need to get different bolts [may want to get stainless bolts for the intake], what do I need to watch out for?
Old Jun 24, 2013 | 03:37 PM
Octania's Avatar
Yes, the torque values are the same for '69 and '75.
Intake bolts are not torqued heavily so SS should work there.
Watch out for?
Crappy Chinese fasteners, grade 2 hardware...
Stick with factory fasteners for the right look or deviate up, like Grade 8's where not necessary- intake, water pump, t'stat housing, bellhouse to block, etc.
Socket head cap screws are very strong also, but generally plain black finish and not that good at rust resistance.
Old Jun 24, 2013 | 04:33 PM
Socket head cap screws come in stainless also.
Here's the torque specs:
http://www.442.com/tech/torque.html
Head:
Intake:
Old Jun 24, 2013 | 05:48 PM
Octania's Avatar
Watch out for?
Old Jun 26, 2013 | 04:01 AM
ctreutel's Avatar
Thanks much!
wcourt3010
Apr 13, 2015 12:10 PM
Don Roberto
Apr 11, 2015 09:48 PM
Franks425442
Mar 9, 2011 12:08 PM
nukesec1
Oct 6, 2009 12:42 PM
mcutlass1969
Drivetrain/Differentials
Aug 18, 2008 09:59 PM
