temp and oil gauge install question
I have a 68 400 and am thinking about installing a set of aftermarket temp and oil gauges. Not that I don't trust idiot lights, but.....I don't. I would like to keep the factory light setup and the mechanical set up. The oil pressure gauge is no prblem to install with a splitter for the sender and hose kit, but what about the temp sender? I have the factory sender in the passenger side manifold hole and the distibutor vacuum switch in the drivers side hole. Is there another place I could put an aftermarket sender for water temp? What suggestions do you all have?
I'm confused. Doesn't the coolant flow split at the front of the engine? A quick look at the lumps on the intake manifold suggest that the left side would be coolant too because the intake runners can be identified with 4 per side coming from the carb.
What am I missing?
What am I missing?
What am I missing?
What am I missing?
The problem in the original post is that there are not enough threaded bungs in that crossover to accommodate the TVS, the existing coolant sender, and the new one for the gauge. Oil pressure senders can be connected with a tee, but this does not work for coolant senders, which must be in the actual flow of coolant.
I am looking to do the same thing with my 350, but I asked the guy at the parts place for a "splitter" for said application and he looked at me like I was speaking Swahili. So, what exactly am I looking for to hook up my oil pressure tubing kit and maintain my dummy light?
d1
d1
d1
1/8" NPT brass fitting, I got mine at Summit Racing, N.O.S. sells them to hook up that stuff. You can do the same thing with a short nipple and female tee but it just doesn't look as clean, that stuff you can get at the hardware store.
There was just a thread on this , dude in Italy was looking for one.
d1
d1
Here is what it looks like installed...
You should be able to get that brass fitting at any well stocked auto parts store. I got mine at my local O'Reillys for about $6. It's a Dorman 43026 http://shop.oreillyauto.com/ProductD...rtNumber=43026
Hey Don,
Thanks for the photo, definitely helps visualize it better. I probably overspent on the one I got coming from Summit. My biggest concern is screwing it into the intake manifold. I got A/C brackets that hug the front of the intake and make it a chore to get at the sender/fitting.
Out of curiosity, on your motor what is the gray/silver sensor next to the water temp sender? Is that a mechanical water temp sensor? Also, for your oil pressure line, is that nylon line covered in rubber hose or did you use copper line?
Thanks again
d1
The aftermarket intakes seem to come with extra bungs for temp. sensors and switches for maximum flexibility.
Hey Don,
Thanks again
d1
Thanks again
d1
Here is what you need for the temp sensor if you are using the stock manifold:
http://www.summitracing.com/parts/ATM-2280/
It installs into one of the heater hoses.
So, it doesn't matter which heater hose? I'd like to keep my water temp dummy light so this is a good option.
Thanks for the link.
d1
There are a couple things to watch for when using the heater hose adapter.
First, if your car has A/C, then you have a shut-off valve on the heater hose circuit. I'm not sure how much coolant flow still goes through this circuit when the valve is closed (i.e. heater is off, selector set to "cold"), but it might not be enough to get an accurate reading on the gauge.
Second, the Autometer 2280 adapter (which fits 5/8" heater hose) only has a 1/8" NPT port. If you are planning to use an Autometer electric gauge this isn't an issue, but if you want a mechanical gauge it won't work.
If you decide to go with an electric gauge and use the heater hose adapter, you might want to use the #2281 adapter (looks identical to the #2280). It fits 3/4" heater hose. Location wise this is a better choice - the long run of hose from your water pump to the heater core is 3/4" (the short hose from heater to engine is 5/8") so it makes it easier to package. And, you ideally want the gauge to read before the heater core. The heater core is just a small radiator, so the coolant coming back to the motor will be cooler than the coolant going into the heater core. In other words, the gauge will read colder than true engine temp if it is in the 5/8" return hose.
Another option would be to use the #2282 or 2283 adapter in your top radiator hose. It comes with all the correct fittings for either electric or mechanical gauges.
d1
