Temp gauge dropped 10-15 degrees: here's how
Old Nov 29, 2016 | 06:50 PM
cfair's Avatar
I the morning swapping out my unknown-age coolant hoses: radiator lower, radiator upper, J bypass, 3/4" heater core, and 5/8" heater core.
The real goal was swapping in a high flow Robertshaw 160 degree thermostat to replace a generic 160 degree to see if it made any temperature difference.
Under the MAW (mightaswell) heading, I flushed the system with distilled water and 2 bottles of Prestone flush for the past 2 days (maybe 40 miles + 15-20 minutes in the driveway).
2 days ago this motor ran just under 180 with a 160 degree generic thermostat. Today it's running 160-170. It's nice to see a gain once in a while.
This car has A/C. When I run it in traffic in Summer, with cr*ppy gas, temps creep up pretty fast - even with a boiled out (brass) 4 core radiator.
To fight the Summer temperature creep I've been living with a very loud 7 blade 19" fan and Hayden 2747 heavy duty fan clutch.
Now finally I can test that 6 blade fan and standard duty Hayden 2765 (quieter) fan clutch with confidence!
cheers
cf
Old Dec 1, 2016 | 05:17 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I use the EP Stewart modified with 3 bypass holes Robert Shaw high flow stats as well. The only issue I had with one was sticking open and very little heat.
tdhill01
Sep 15, 2016 04:01 PM
getitmann
Jul 12, 2012 06:58 PM
Emreozd
Feb 19, 2012 06:27 AM
Giddy
Jul 23, 2011 01:28 PM
moberg
Mar 4, 2009 12:13 AM
