surface rust on a block
Old February 13th, 2008, 10:48 PM
shaks 442 clone's Avatar
how bad does this block look
i got the ok from my machine shop teacher i come into the shop at 6 30am work till 8am and then go to my first class
so he said i could use all the machines in the shop they have a bore machine hot tank a resurfacing machine for heads, and engines i think
the machinist looked at my problem cylinder and saw it was deep to the point where it needed to be sleeved but he said even before you sleeve it inspect the block for an cracks because if there are cracks you just wasted 100 dollars on a sleeve
http://images.craigslist.org/0101060...538200fcbc.jpg
http://images.craigslist.org/0101080...b22300b8d7.jpg
http://images.craigslist.org/0102030...a8ad00ccf9.jpg
shaks 442 clone is offline
Old February 14th, 2008, 04:42 AM
Past Administrator
Oldsguy's Avatar
It LOOKS like a normal block to me but that really doesn't say anything. Do what your teacher recommends and check the block for cracks. Do you maganaflux?
Oldsguy is offline
Old February 14th, 2008, 05:16 AM
That seems like a decent engine. Make sure you magnaflux it. You could also use Zyglo to check for cracks. You want to check head surfaces and near the main journals.
Olds64 is offline
Old February 14th, 2008, 11:27 AM
i dont think they have a magnaflux machine at school but the teacher owns a machine shop of his own and i'll ask him if he has one there
by the way thats not my block in the pictures i found a guy down the street from my house selling that block its a 1969 455 block F series
blunce
Body work
19
February 16th, 2013 08:16 PM
Delmont 88 PA
Body work
May 25th, 2012 09:28 AM
Del70
June 3rd, 2011 01:01 PM
Del70
May 22nd, 2011 01:31 PM
t_visker
December 29th, 2006 08:59 PM
Quick Reply: surface rust on a block
