Stumble above about 4300
Old September 30th, 2020, 08:46 PM
NotDads442's Avatar
For starters I own a shop and being 39, I usually let my shop foreman work on my Oldsmobile, he’s our guy on the older stuff.Anyhow. We can’t seem to get a sputtering stumble to go away around 4200-4300 around to 5500. We bumped up base timing and the car seems to like 21 initial. It definitely gets better as it warms up.
If your at those rpm ranges at 80% throttle it seems to be fine but if you give it all the coal it can’t smoothly go through that last 1000 rpms.
Running a stock distributor with pertronix hei. Engle cam, I think 3rd grind from the bottom. Mahle ported pistons. Blocked off heat risers. Comp magnum rockers.
2600’ elevation.
I’ll be glad to give you any more information you might need
NotDads442 is offline
Old September 30th, 2020, 09:12 PM
You've got way too much initial timing, drop it back to 12*. Your Pertronix is a points replacement electronic trigger, not an HEI.
oldcutlass is online now
Old September 30th, 2020, 09:49 PM
NotDads442's Avatar
will 12 fix this?
1969cutlassS
July 15th, 2018 06:38 AM
olds 307 and 403
June 20th, 2017 07:38 PM
KDW
October 17th, 2014 02:54 PM
Gustav455
June 18th, 2010 12:28 AM
iam2fast4u86
July 8th, 2009 03:57 PM
Quick Reply: Stumble above about 4300
