Steel shim head gaskets
Old Feb 12, 2024 | 07:33 AM
DROLDS707172's Avatar
Finally going to use my nos GM steel shim head gaskets, should I coat both sides with copper spray? Was going to put a light skim of rtv around the cooling passages. Looking for some advice. Thanks
Old Feb 13, 2024 | 07:16 AM
67OAI's Avatar
Old(s)GuysRule
You can coat them with copper aerosol spray or any other aerosol gasket sealer. Should not be necessary to use RTV around the cooling passages. Have the cylinder heads been checked for flatness?
Old Feb 13, 2024 | 07:33 AM
Shim head gaskets
Heads are flat, cast iron "C" castings ported by mondello back in the early 90s, block is all original GM assembled out of a 70 Vista with approx 70k on it.
Old Feb 13, 2024 | 08:04 AM
x2 on using copper spray
Old Feb 13, 2024 | 10:55 AM
Sugar Bear's Avatar
I'd confirm that the block and head are flat straight, use copper spray on both sides. No RTV.
my71olds
Aug 14, 2013 05:49 PM
joepenoso
May 22, 2013 08:38 PM
DENT
Oct 31, 2012 02:08 PM
pavemobile
Oct 8, 2012 06:15 PM
smcurro
Feb 11, 2009 08:47 PM
