Starter for 72 455
Starter for 72 455
I need to replace my starter and it is not original, 1109072 9C13 Delco Remy US2 which is a 79 403 high torque starter. I think I want a 1108387. Does that jive with common wisdom?
If I understand you correctly you want an OEM starter for your 72 455? Try graygracy, a seller on ebay. I've made a number of purchases from him and no problem. Message him if its not listed. Ask him to provide picture of starter and stamping number/date prior to purchase; he will glady comply.
https://www.ebay.com/itm/25085194747...QAAOSwKwVac2gJ
Hope this helps.
Hope this helps.
Based off some number looking, the 1108389 was on 1970 455 all, and the 1108387 was on 71-72 455. Not sure of the mechanical difference of these. Date code would need to be 2C## or earlier for an 04A car.
Hope this helps.
Hope this helps.
