Someone care to explain this casting code?
Old Jan 22, 2011 | 07:09 AM
TK-65's Avatar
65 425
Old Jan 22, 2011 | 08:20 AM
Oldsguy's Avatar
Past Administrator
That's a beer drinker for ya! Can find an association to beer when others can't.
Old Jan 22, 2011 | 10:22 PM
Mister's Avatar
I can decipher some of the numbers, using the Olds FAQ here. Unfortunately the numbers don't tell you anything you didn't already know.
"386525" is the casting code for the block. That code was only used in 1965.
The capital letter "A" is an ID code. Again, specific to 1965 engines. That ID code, for what it's worth, is a quick way to distinguish an Olds big-block from a small-block. BBOs will have a letter there, whereas SBOs will use numbers instead.
Interestingly, the FAQ indicates that the ID code normally precedes the casting code. I've got a '66 425 with ID code D, but I don't remember exactly how the numbers are placed on it, nor if there are any extra numbers.
I don't know what the last two 3s mean. If the whole reason for your post was to figure out what the 3s were, then I apologize for wasting your time.
Old Jan 24, 2011 | 04:59 PM
507OLDS's Avatar
I saw an A1 block at Smitty's last week.
Giddy
Dec 16, 2011 10:45 PM
bobb
Feb 3, 2011 08:24 PM
jaunty75
Oct 16, 2010 01:22 PM
Jamesbo
Dec 16, 2009 03:23 AM
jeffs 89 cutlass salon
Nov 5, 2007 05:48 PM
