valve cover breather location
Old Jan 24, 2011 | 11:50 PM
rcdynamic88's Avatar
I am looking at a set of the GM Performance cast aluminum "Oldsmobile" block letter valve covers. They don't have any holes on them for a breather or PCV valve. There are two Olds rocket emblems on either side of the Oldsmobile lettering that are located in a circle shaped area, does anyone know if there is a "knock-out" in that spot?
What have my fellow Olds fans done when using these valve covers? Any pictures would be appreciated.
Old Jan 25, 2011 | 06:37 AM
507OLDS's Avatar
I have those valve covers.There is NO knock-out spot,or thinner area to make a hole.I just drilled through one of the rockets.If you can cut a circle around the hole,to remove the higher spots from the rocket,your breather gromet will fit better.
Old Jan 25, 2011 | 08:15 AM
jo75olds's Avatar
This is something that has always bugged me, I don't own these valve covers as I think they are a tad overpriced, but WHY WOULD THEY NOT PUT A BREATHER HOLE?
Old Jan 25, 2011 | 08:20 AM
507OLDS's Avatar
Each person wants to put the breather in a different location,or they might also weld evac fittings on the ends,for a vacuum pump,or whatever.
that's the same reason I never end up buying a used set.I never like where they put the hole,or what they did to them.
Old Jan 25, 2011 | 08:47 AM
jo75olds's Avatar
True, but I would hate to cut into those, there soooo pretty
tkw31
Oct 4, 2012 10:02 AM
Chuck_66
Aug 20, 2012 04:18 AM
cessna195
Mar 8, 2010 10:29 AM
dallasite21
Jan 27, 2010 07:23 PM
