Solid motor mount
Solid motor mount
I've been wanting to do a solid mount on the drivers side for some time. I finally bit the bullet and designed and built my own. My car has a 455 with what appears to be small block mounts and frame pads. The OE style mount has part #2261 on it.
I bought a new mount at O'Reilly for the tidy sum of $3.29 and used it to fab up a jig to give me the proper mounting holes and angles needed. I made a few different mounts making changes until I came up with one I liked.
Jig
Jig with stock mount
The mount I made has 3/8" mild steel for the engine mount side and 1/4" mild steel for the angled pieces going to the frame pad.
Tacked together
I'm fortunate enough to have access to a Bridgeport mill so all pieces were created with it.
TIG weld before paint.
Painted and ready for install.
Installed
Jig
Tacked together
Installed
hey buddie if this is not permanetly installed yet it could rattle you real good with decent power. I use a competition engineering torque limiter with a rubber mount and it does not seem to be to bad to deal with. I am almost definite that solid mounts are great for wheelie cars though maybe that could be your cue to do it though.
Jig
Tacked together
Installed
Jig
Tacked together
Installed
Nice work, though as a structural engineer I would recommend a small web tying the two tabs to the mounting plate to avoid any fore-aft flexing and potential weld cracking. I'm assuming your car was originally an SBO, thus the 2261s in a 1972.
As for why only one, only the driver's side is in tension when accelerating. The passenger side rarely fails.
