smoke from carb
Old Dec 14, 2007 | 05:09 PM
1973_442's Avatar
smoke from carb
hi, im having a problem figuring this out, when i try to start my car it backfires and has white smoke coming out of the carb. what could cause this?
Old Dec 14, 2007 | 05:16 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Distributor is in 180 degrees off?
Old Dec 14, 2007 | 07:25 PM
2blu442's Avatar
Did you change your plug wires and possibly used the wrong rotation? Clockwise or counterclockwise for the firing order?
Old Dec 15, 2007 | 06:21 AM
A little bit more info would be good. Did you just do anything to the car? Have you set your timing recently? Do you have any aftermarket parts on it like a hot cam or carburetor?
Old Dec 15, 2007 | 03:02 PM
1973_442's Avatar
yeah i just replaced the spark plugs and wires, and i also got an hei rebuild kit, with rotor, cap, condensor, coil, ignition module. no i havent set the timing. its got a douple pumper carb, but ive never had a problem with it before, its been on the car since i bought it. also i cant find a wiring diagram for spark plug wires to an hei, i replaced them one at a time but i just want to double check, my chiltons only has diagrams for conventional distributors. any one know of any? its a 1973 442 with a 350 (sorry, i posted this in the small block forum but it ended up here somehow)
Old Dec 15, 2007 | 03:23 PM
2blu442's Avatar
Check the plug wire order and rotation on the distributor. I'm speaking from experience, I have put the plug wires on in the wrong rotation! The firing order should be 18436572 and is cast into the intake manifold. Then on the distributor it should go in a counterclockwise rotation. You can have the right order, but if they're put on the distributor cap in the opposite rotation you'll get all kinds of backfiring out the carb and exhaust! John
Old Dec 15, 2007 | 04:59 PM
I think John hit the nail on the head. Especially since you just put in a new distributor. Let us know what happens once you double check everything and make some adjustments.
Old Dec 15, 2007 | 05:13 PM
1973_442's Avatar
i rewired it and the car tried to start, had a backfire, but didnt smoke out of the carb! it sounded right though when it tried to start. its just that the air adjusment screw seems to have disappeared from my carbuerator...
but anyways thank you!
defiant1
May 28, 2011 06:41 AM
ct1979
Mar 10, 2008 01:10 PM
54olds
Nov 27, 2007 05:08 AM
ztim
Sep 20, 2007 04:03 AM
77 oldsMAbrotha
Aug 22, 2007 04:00 PM
