Size of spacer for W/P bracket to front of block
Does anyone know the actual size of the spacer that goes here? Seems to be the only thing need to locate in my huge pile of Olds hardware. Thanks!
I've purchased numerous seamless steel spacers of various sizes for many applications from Ace Hardware - check in their hardware bins selection area. I've seen them at other stores e.g. Lowe's, Home Depot, etc., as well.
Google search (seamless steel spacers) yields >>> https://www.google.com/search?q=seam...nt=products-cc
That works too, and you can grind the spacer to the correct length on a bench grinder. I've already got a coffee can full of washers, so that's easy. Of course, these days I also have a container full of PS pump spacers that I've harvested off of parts cars.
