Shaving Exhaust Manifold Mating Surface BBO heads
Old Mar 29, 2017 | 01:18 PM
VinMichael's Avatar
Does anyone know how much can be taken off? I have a set of heads that have a bad surface. Thanks in advance!
Old Mar 29, 2017 | 02:45 PM
young olds's Avatar
I've had a set of c heads milled until they had a flat spot on the center divider.
Old Mar 30, 2017 | 07:08 AM
Run to Rund's Avatar
I have had them cut 0.190" to bring the center divider up flush.
Old Mar 30, 2017 | 08:23 AM
jensenracing77's Avatar
I could be wrong but I do not believe the stock exhaust manifolds will fit if you mill it to the center divider? I thought I remember the manifold hitting the block.
Old Mar 30, 2017 | 08:35 AM
TripDeuces's Avatar
I know for a fact that certain headers and maybe even some manifolds will hit the block with that much surfacing of the exhaust side. That will depend on the design.
All I'm saying to the OP is that there is no hard and fast rule. You do it, you test fit and then you might have to modify another component to adjust. That's the fun of car crafting.
If you have the heads off you could also use silicon bronze mig wire to fill in the gap and then surface it flush. Silicon bronze mig wire is a great filler and acts more like brazing than a weld.
Many ways to skin a cat.
Old Mar 31, 2017 | 06:26 PM
VinMichael's Avatar
I might have a set of usable heads. Only paid $80 for them. They are GA and it turns out they have pressed in hardened exhaust seats and big valves. The machinist said I may need new valves since someone chopped the tops of the valves flush with the rotators and the rocker tips are practically sitting on top of the rotators. I am going to try some retainers since they should sit lower than the valve stems compared to the rotators to avoid new valves. The guides are good enough.
I do have a mig welder but never tried welding cast iron, always heard horror stories about it
Oldssupreme
Sep 17, 2016 04:39 PM
QS442
Oct 15, 2013 05:38 AM
joepenoso
Apr 10, 2013 06:19 AM
442b
Jun 20, 2011 08:06 PM
64rocketman
Jul 16, 2009 07:17 AM
