Shaving cream in the water jacket??
Old Apr 9, 2013 | 04:06 PM
joepenoso's Avatar
Question Shaving cream in the water jacket??
The Mondello tech centre web site there is an article called " Rebuilding your first engine" in it on the last page after "Final engine assembling" is.................................
"The cylinder head water jackets need to be blown out thoroughly to remove any dust, dirt
or rust scales. If your water jackets have a lot of debris still left in them, use some shaving cream
(Gillette Foamy is the best)"
What's up with the shaving cream??? Does it clean the water jacket? Does it show leaks faster??
joepenoso
Old Apr 9, 2013 | 04:13 PM
gearheads78's Avatar
car guy
Never heard that one before.
Old Apr 9, 2013 | 04:30 PM
Tedd Thompson's Avatar
Just a guess, it is more viscous than water( thicker) and will pull junk out better than water( more service tension). That was a WAG so take it for what it cost you....Tedd
Old Apr 9, 2013 | 04:56 PM
don71's Avatar
same but different
Hmm..never heard that one before either. April the 1st was over a week ago!
Off to search the Ph of shaving cream...
Old Apr 9, 2013 | 06:40 PM
Lady72nRob71's Avatar
Maybe it is only supposed to be used if you shaved the heads...
Old Apr 9, 2013 | 06:44 PM
I saw that "tip" on Horsepower TV. The idea is the shaving cream will keep debris from the cooling ports from falling into the engine when you bolt them on. The shaving cream will dissolve in the coolant, leaving the crap in the cooling passages to collect elsewhere. This seems to me like putting a Band-aid on a gunshot wound, or wiping before you poop, or any other saying you would like to use. It seems to me it would be much better to CLEAN the part before assembly than try to keep debris from critical places.
Old Apr 10, 2013 | 06:19 AM
joepenoso's Avatar
The "shaving cream" was written by Mondello. he knew his **** when it came to Oldsmobiles and it was at least 5 years old??
joepenoso
J-(Chicago)
Nov 12, 2013 03:40 PM
zodiacblueS
Sep 11, 2011 07:23 PM
442b
Jun 20, 2011 08:06 PM
Flye
Aug 24, 2009 05:46 AM
