Setting Lifter Preload - Roller rockers
Old Apr 17, 2018 | 12:28 PM
VinMichael's Avatar
So I’ve read quite a few different methods of doing this. EOIC, etc. But my question to those who’ve done this is what is the simplest way of doing this procedure? Meaning the least revolutions of the crank and cam.
I’ll add that the guide plates aren’t adjusted yet, so I’d like to add that adjustment into the work flow. I know we shoot to adjust when the lifter is on the base circle. So my question is what’s the most efficient way of getting there.
Im working with flat tappet lifters (dry, not pumped up), 7/16” stud with polylocks, 1.65 stainless roller rockers.
I am getting the right rocker geometry with 2.8 turns of the polylock. .050” per turn with 7/16” studs. Lifter preload is right around .030”
thank you
Old Apr 18, 2018 | 06:24 AM
If you take the engine firing order and split it in half and arrange them to look like this
1843
6572
you will be able to figure out companion cylinders. Set #1 at TDC, you can adjust the valves on cylinder 1 and 6. Rotate the engine in the normal direction exactly 90*, set the valves on 8 and 5. Rotate another 90, set 4 and 7, another 90 and 3 and 2. You just set the valves with one turn of the engine. This is probably the easiest/fastest method. It helps to have a degrees balancer
Old Apr 18, 2018 | 07:17 AM
cdrod's Avatar
Rodney
^^This^^
I did mine exactly the way Matt69 described.
Old Apr 18, 2018 | 09:28 AM
69455's Avatar
Olds is the same
File Type: pdf
Old Apr 18, 2018 | 11:02 AM
jensenracing77's Avatar
I am a little slower but I don't trust myself with the above. I have several friends that do it that way. I just start with hole 1 and go in the firing order one at a time. It ends up being two rounds of the crank.
Old May 10, 2018 | 09:36 PM
VinMichael's Avatar
Thanks guys for your advice. I was able to make sense of this. All was put into perspective.
Old May 11, 2018 | 09:13 AM
bw1339's Avatar
I've used this with AMC engines (same firing order).
http://www.pontiacstreetperformance....p/rockers.html
1968Cutlass_S
Mar 18, 2018 04:43 AM
AlphaOmega74
Mar 17, 2015 09:18 AM
rsandhoff
Jan 27, 2010 05:58 PM
Redog
Aug 14, 2008 06:56 PM
#1CutlassSupreme
May 13, 2008 10:40 AM
