"Seez-Pruf" nuts
Old Mar 2, 2011 | 10:08 AM
trackz man's Avatar
"Seez-Pruf" nuts
Replacing the heat valve on my 1963 Starfire 394V8. According to the 1963 service manual- Note: Always use new gasket and "Seez-Pruf" nuts when replacing the heat control valve....
Looking for answers on what is the best type of nut-bolt combination to use on this very hot area of the exhaust...
If I use ordinary nuts-bolts I feel that they will weld themselves since all the expansion contraction cycles. It would not be a happy sight to have to remove those later on down the line
What is your best answer and experience with this?
Old Mar 2, 2011 | 10:29 AM
Bluevista's Avatar
Registered
I use high temp anti-seize compound on the exhaust flange stud threads and they always come loose okay for me, use it on the muffler clamps too.
Old Mar 2, 2011 | 10:38 AM
stan 65 cutlass's Avatar
if you use brass nutts they wont corrode, ive used em on exhaust manifolds
Old Mar 2, 2011 | 10:56 AM
X2, although I've also had success with the high temp anti-seize. I've also used stainless, but I've had problems with them galling on removal.
Old Mar 2, 2011 | 11:24 AM
trackz man's Avatar
Thanks guys for the reply- I will go with high temp anti-seize and brass nuts.
You guys are...
Old Mar 2, 2011 | 11:42 AM
and yes, brass nuts are different than brass *****
Old Mar 2, 2011 | 12:14 PM
trackz man's Avatar
I was waiting for someone to make a comment like that...
Old Mar 2, 2011 | 12:26 PM
True - but it is possible to have both.
... In your TOOLBOX, I mean.
Wait... That didn't sound right either...
Old Mar 2, 2011 | 12:34 PM
trackz man's Avatar
MDchanic-
Did you say that outloud, or were you just thinking that- WAIT- I see you actually typed that
Old Mar 2, 2011 | 12:36 PM
Wow, man.
Old Mar 2, 2011 | 12:47 PM
did you say box?
Old Mar 2, 2011 | 02:30 PM
greenslade's Avatar
may you should say tool bag
Old Mar 2, 2011 | 02:31 PM
Just not going there!!!
Old Mar 2, 2011 | 03:08 PM
I've gotta say that nobody wants their nuts to seize (or to be seized), so seez-pruf nuts would be a godsend.
And, in fact, I do keep my tools in a bag (actually 2 bags ) - less weight and easier to transport that way.
Old Mar 2, 2011 | 03:56 PM
trackz man's Avatar
Okay- Where are the mediators when you need them- or maybe they are contributing to this thread.....??
65JS1
Jan 12, 2015 11:05 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
Tom442
Jul 25, 2011 02:46 PM
88hurstolds
Dec 28, 2008 08:29 PM
