Reusing the turkey tray
Old Dec 5, 2023 | 05:21 AM
PaulWinn's Avatar
Curious about reusing the valley pan metal gasket. I realize the raised impression may be smashed a bit, but if it is going on the same motor with same intake, and I put a smear of rtv around, why wouldn't it work? Pretty expensive part nowadays
Old Dec 5, 2023 | 05:49 AM
tru-blue 442's Avatar
Old School Olds
Don't do it, you'll be sorry....I used to get them from Pep-Boys pretty cheap, you may try them.
Old Dec 5, 2023 | 06:25 AM
No, no, no. This is a one-time-use item only. The raised beads crush to conform to the exact joint. No matter how careful you are, parts will never go back exactly the same way.
Old Dec 5, 2023 | 06:38 AM
If you cut the side rails off of the turkey tray you could reuse the turkey tray with an aftermarket gasket, but not the side rails themselves. IMHO, just get a new turkey tray gasket, cut the turkey tray out and throw it away. I've never been able to get the whole turkey tray to seal properly.
Old Dec 5, 2023 | 06:46 AM
Sorry, but this is where I'll have to point out that Olds literally built tens of millions of engines using the metal intake gasket that all sealed just fine (and that includes iron heads with iron intake, iron heads with aluminum intake, and aluminum heads with aluminum intake on the 215s). In half a century of working on these cars, I've never had a leak after reinstalling an intake with the metal gasket when following the instructions in the CSM. As I've said many times, dry fit the gasket first to ensure the four locating bosses fit into the holes in the heads. Use RTV as shown in the CSM.
Old Dec 5, 2023 | 07:12 AM
67OAI's Avatar
Old(s)GuysRule
Ditto what Joe said! I too have only used the metal turkey tray intake gasket and had no problems with getting a good seal.
Old Dec 5, 2023 | 07:27 AM
In the years I've been coming to this site I've never read how Oldsmobile employees installed the turkey tray gasket. Was the iron intake manifold on a crane or jig, or did the line workers just muscle it onto the engine?
I've tried to use the turkey tray gasket in the past. Unfortunately, I've never succeeded. IMHO, this is the best way to install the intake manifold:
  1. Cut the sides off of the turkey tray gasket
  2. Throw away the turkey tray
  3. Throw away the lifter valley end rail gaskets
  4. Use Right Stuff gasket maker to seal the lifter valley end rails
  5. RTV per the manufacturers instructions on the side rails
https://www.oreillyauto.com/shop/bra...inute/per/pery
Old Dec 5, 2023 | 10:34 AM
Run to Rund's Avatar
I have a bunch of these steel intake gaskets and they are probably worth less than today's shipping costs. I never re-use them. Put Permatex 3D (brush-on liquid) at the intake ports, and RTV at the water ports. Don't use RTV at the intake ports because gasoline turns it to slime.
Old Dec 5, 2023 | 12:00 PM
If you're not gonna use the inner tray part, just get the separate 2 piece gaskets instead.
FEL-PRO MS99471
https://www.rockauto.com/en/moreinfo...&pt=5424&jsn=8
Old Dec 5, 2023 | 02:53 PM
Thanks for the link/part number.
67442nut
Mar 22, 2015 10:16 AM
hackmansr
Sep 17, 2014 05:48 PM
1971cutlas
Sep 23, 2013 02:10 PM
archerbob
Aug 27, 2011 11:55 AM
RAMBOW
Mar 5, 2011 06:48 AM
